GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
cant get CB radio working
Old Mar 18, 2009 | 08:44 AM
DupermanDave's Avatar
I've got my grandfather's old CB radio setup in my truck. It's wired directly to the battery. The antenna I have is the same antenna that's been with the CB for 20 years.
The radio seems to work, I can get see I get signal (signal strength meter) but I can't hear anything. I can hear the clicking of my mic going on and off, but I can't hear anyone else.
I've played with the squelch and can't get the thing to work. Any ideas?
Old Mar 18, 2009 | 08:49 AM
algranger's Avatar
RF Gain all the way up and start turning your squelch up from the bottom. Done that yet?
Old Mar 18, 2009 | 09:43 AM
olharleyman's Avatar
blown speaker? try an external speaker see if that works
Old Mar 18, 2009 | 09:45 AM
Yup. Turned it clockwise (and counterclockwise) very slowly for channels up to 13. Gave up at 13 because I figured something was broken.
I also have a delta - and + knob that I've adjusted. I've tried adjusting multiple combos of settings.
I thought it was a blown speaker too, but it still clicks when using the mic, and I can hear interference coming from the radio inside my truck. So the speaker still works.
Is it safe to say it's broken? :-( I won't buy a new one, i'll just take this to a repair shop (too much sentimental value)
algranger's Avatar
Or your not getting the signal from the antenna into the unit
Old Mar 18, 2009 | 09:46 AM
algranger's Avatar
Yeah it sounds like it's broken. See what the repair shop says
Old Mar 18, 2009 | 09:52 AM
finals shot
Old Mar 18, 2009 | 10:11 AM
Antenna seems fine, as I can unplug it and watch the signal strength drop. There's a few additional switches I forgot to mention. There's 3, to be exact. One is for PA, and the other two I can't remember off-hand. would a picture help?
Old Mar 18, 2009 | 10:16 AM
algranger's Avatar
Heh i'm sure the shop will be able to get 'er goin
I've got my grandpa's old cb in my truck too
Old Mar 18, 2009 | 11:14 AM
Wow. Mine is mounted in the same spot in my truck, but it's a lot cleaner, lol.
So which shop should I try first? CB radio shop or electronics repair shop?
Old Mar 18, 2009 | 11:30 AM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
You need to tune the antenna to the radio. Thats your problem. Go to radio shack, and purchase a RF/signal strength meter. It'll come with instructions on how to tune the antenna to the radio and the vehicle. Less than $20 (IIRC), and 1/2hr of your time.
Old Mar 18, 2009 | 11:43 AM
Originally Posted by a4runnerfreak
You need to tune the antenna to the radio. Thats your problem. Go to radio shack, and purchase a RF/signal strength meter. It'll come with instructions on how to tune the antenna to the radio and the vehicle. Less than $20, and 1/2hr of your time.
Ah, ok. I'll check it out. I don't expect a detailed explanation, but how do you "tune" an antenna with a CB radio?
The antenna I have now is the one that's been with the CB radio for a long time now, so does it still need tuned?
Old Mar 18, 2009 | 11:48 AM
Dirt Master80's Avatar
you have to buy the cb tuner that hooks up inline between tthe antenna and the cb, buy lifting or shorting the tip of the anteena you (tune) the cb, the meter measures ressistance and your trying to get as little ressistance as possible for the best signal
Old Mar 18, 2009 | 11:49 AM
Ah, if I have the lengthen or shorten the antenna, I'll have to buy a new one. The one I have is pre cut and shortened. IT's about 2 1/2 feet long.
Old Mar 18, 2009 | 11:58 AM
correction: not the anntena just the anntena wire that is wraped around the anntena
Old Mar 18, 2009 | 12:02 PM
Hmm. I'll have to look more closely for that. My antenna goes down to a springy base, and the base is then a round magnetic clump. I'll go out and check on that.
Could you guys also be talking about the length of coax cable running from the antenna to the radio?
Old Mar 18, 2009 | 12:08 PM
the lenght of the cable can affect tuning also. just so you know im not shure tuneing is your problem. usally the cb will work out of tune, it just usally works much better after its been tuned
Old Mar 18, 2009 | 12:39 PM
Hmm. Okay, I'll hold off messing with anything until I get more suggestions. I'm clueless when it comes to radios and tuning, but I'm an ace when it comes to computers and home audio/video equipment.
I just thought of this, but I have the antenna mounted on the toolbox behind the read window of my pickup. I know it's suggested they be mounted on the roof, but is it THAT big of an issue to have it mounted where I do?
Old Mar 19, 2009 | 06:42 AM
I've been researching more online, and everyone recommends having the antenna rise above your roof by 3-4 inches. I checked my antenna, and it is up by 4 inches.
-edit- it's not the speaker. I have an AUX headphone jack I can use and it still doesnt bring any signals through. Took apart the radio and used a multimeter to verify the speaker was working still, and it is.
Old Mar 20, 2009 | 07:11 PM
Third post just to get a final update: I think I'm going to take it to a shop to have it repaired. Question is, can it be repaired? Are some electronics not fixable? This thing is from the 70s, so I would think it can be fixed. I took it apart and seems pretty do-able. Anyone with experience know what it might cost? I'm going to a CB shop sunday and seeing if they can fix it.
MO transplant
Apr 23, 2023 11:58 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Johntom240
7
Jul 13, 2015 12:18 AM
madxman21
Jul 9, 2015 10:26 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
