Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
What's the red wire with black strip for?(radio)
Old Apr 15, 2016 | 01:52 PM
d-wood's Avatar
1993 pickup dlx 4x4.
I installed an after market stereo and I'm not getting any sound from my speakers. I hooked all my wires correctly. The only wire that's unaddressed is the green one and the red with black strip.
Attached Thumbnails What's the red wire with black strip for?(radio)-photo325.jpg
Old May 5, 2016 | 10:42 AM
SCLead's Avatar
I have the AM/FM radio only, no cassette, etc.
Green one is apparently "Radio Illumination," most online diagrams say not to use it at all. It doesn't have a label or callout associated with it at all in the FSM. I get slightly varying voltage while adjusting the dash light dimmer knob with the headlights on.
Red/black on my 92 dlx 4x4 was the only wire connected to the second plug on the back of the stereo. It is called out as "to Rheostat" in the FSM, and ringing it out with a voltmeter shows nothing with headlights off, and variable voltage with dash light dimmer knob when headlights are on.
I'm still waiting for my head unit to arrive, but I'm counting the red/black wire as the dimmer control.
All that said, I haven't tested the function of my theories, so don't get mad at me if you hook it up as dimmer and your house explodes.
Old May 7, 2016 | 10:14 AM
d-wood's Avatar
No worries. Yeah I don't get any readings on it either.
Old May 7, 2016 | 10:41 AM
SCLead's Avatar
So my stereo came in. I repinned the red wire into position "A10" on the main connector - replacing the green wire with the red/black wire in that connector. I capped off the green wire (not using it at all) and connected red/black to the dimmer wire on my head unit. 100% function out of the aftermarket stereo, including dimming with dash lights, and full brightness when dash lights/headlights are turned off.
Hope that helps.
Old May 8, 2016 | 09:23 AM
d-wood's Avatar
That does. Thanks!!!!
cat100
3.4 Swaps
Apr 6, 2016 08:44 PM
93
Apr 1, 2016 10:49 AM
Bajawfo
11
Mar 30, 2016 04:49 AM
Havokgs
Mar 29, 2016 01:33 PM
mudharvest23
Mar 26, 2016 08:22 AM
