Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Recommend me a 1-ohm stable 1000-1200 watt amp
Old Aug 22, 2006 | 03:04 PM
89macrunner's Avatar
As the title states..show me what you guys think..I do have somewhat of a budget.
Old Aug 22, 2006 | 04:12 PM
wjwerdna's Avatar
why two smaller 1ohm amps?... youd be able to go with two 2 ohm smaller amps....
if you want a good amp, the only thing i will recommend is a mtx 1501d... but that may be a little more than you are looking for. 1500 at 2ohm i ran mine at 1 ohm all the time though
Old Aug 22, 2006 | 04:14 PM
wjwerdna's Avatar
im guessing you are running two 4ohm DVC subs.... so each speaker, with coils run in Parallel, you have two speakers at 2 ohm each, you put those together once again and you will need one 1ohm stable amp, but if you split it up between two amps, they will each only need to be 2ohm (X1...mono) rated
Old Aug 22, 2006 | 05:11 PM
yes but than i need to somehow hide 3 amps and lots of 0ga wires..I had a mistake in my first post. I only want to run one amp for my subs...
Old Aug 23, 2006 | 11:39 AM
ldivinag's Avatar
lol... big contradiction there...
budget and 1-ohm stable 1000-1200 watt amp...
at this point, how much is the budget for the amp?
Old Aug 23, 2006 | 03:43 PM
$400-500
Old Aug 23, 2006 | 04:05 PM
wjwerdna's Avatar
thats a decent budget for JUST the amp... if you can find a good deal, and not get ripped on a used one
Old Aug 23, 2006 | 04:21 PM
Heres what i am looking at:
MTX TA7802 which puts out 1200watts RMS @ 1ohm
It runs about $400 from Hookedontronics.com (GREAT site)
I think thats what im going to be going with.
Old Aug 23, 2006 | 04:22 PM
wjwerdna's Avatar
Kicker SX1250.1 - 1250rms@1ohm = $999.95 down from 1200! what a deal
MTX Audio TC6001 600rms@2ohm, if you dare you may be able to run 1000-1200@1ohm - $383 down from (450)
Orion HCCA-D2400 1200rms@1ohm - $524 down from 700
Power Acoustik A1800DB 1400rms@1ohm (yeah...) - $290 down from 500
I've given up on trying to find good deals used or on ebay for car equipment, give www.sounddomain.com or www.etronics.com a shot, I don't have any personal experience with the above amps, just what I would consider with your budget... Orion is known to be pretty high class... search froogle or such to find if these prices are competitive and read all the reviews you can find for anything you buy. always. Also, im assuming you want RMS rating, if you want 1000-1200 max, you will be even more set on finder lower prices
Old Aug 24, 2006 | 01:29 AM
mdh's Avatar
mdh
If you want a decent budget amp check out the hifonics brutus
http://www.speedsound.com/product.as...ific=jmrrlndng
I never have used one but i have read it is ok/reliable for a class d budget 1k amp.
I have dealt with norman @ speedsound and he is a stand up guy.
Old Aug 24, 2006 | 07:54 AM
Bumpin' Yota's Avatar
$400-500
orly? :evil grin: :evil grin:
Time to buy two MTX 1501D's, strap them (I can guide you - its very easy to do) and rewire your subs to a 4ohm final impeadance! Whola 3kW rms! You better get a G31 optima blue top up front and probably a nice big 130 amp tundra alt.
With that much power on tap you would have to watch the subs excursion below the tuning of 34hz. Well probably at most all frequencies further than about 1/2 octave a way from 45hz. But inside the 35-55hz range it will rip yer head off!
Old Aug 24, 2006 | 08:04 AM
wjwerdna's Avatar
ahh yes, a couple 1501d's... that was my old plan 'back in the day' instead ran one at 1 ohm on two 15's in 8 cu ft... one is good
Old Aug 24, 2006 | 08:57 AM
where one is good, 2 is better, and 4 is BEST!
(32 of em would be straight up baller though!!)
Although he would be stressin those Type Rs if he wasnt careful...lol
Old Aug 27, 2006 | 02:32 AM
4-RUNNIN' FREAK's Avatar
http://ampguts.realmofexcursion.com/...ower_T10001bd/
http://search.ebay.com/search/search...1bd&category0=
http://froogle.google.com/froogle?q=...line&scoring=p
The BS RF birthsheet for my 30001bd states an extra 1000 watts at the 2 ohms I will run it at, So I will have 3000, and not 2000.
Old Aug 27, 2006 | 06:29 AM
iruny4wd's Avatar
Actually at 1ohm loads the Brutus line really does not perform. They are highly overrated. Take the BX1800D for example, supposed to do 1800rms at a 1ohm load but every bench that i've seen it actually only came out doing around 1450rms. At 4 and 2 ohms it performed just how it was supposed to, even a few watts better, but at 1ohm it is far from it's labeled numbers. Just try to stay clear of the brutus line if possible.
Davebarbier
Nov 3, 2015 03:28 PM
Kamaloha
Oct 16, 2015 05:13 PM
1985 4Runner
Sep 30, 2015 10:17 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
toyotasaurus
Sep 24, 2015 03:30 PM
