Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Power Antenna Will Not Stop
Old Jun 30, 2006 | 11:45 AM
4runner46's Avatar
Question Power Antenna Will Not Stop
Ok, the nylon cable on the antenna of my 97 4runner broke, so I replaced it. It worked great for a few days, but now I have a problem: when I turn the radio on, the antenna goes up, but when it is fully extended the motor continues to run for about 15 seconds, grinding gears. Going down the motor stops fine. Does anyone know how I can get the motor to stop when the antenna is extended like it used to? thanks
Old Jun 30, 2006 | 11:57 AM
User 051420's Avatar
Try taking it out and re-feeding it. It may have jumped a few teeth. I'd bring it all the way up, and have somebody send it down while you feed it in.
Old Jun 30, 2006 | 05:05 PM
Elton's Avatar
mine is broke so i unpluged it and pull it all the way up works fine
Old Jul 1, 2006 | 12:15 AM
msw0085's Avatar
Ive had to do that on both of my 4runners..
If you do this, be warned: Drive thru car washes are not your friend
Old Jul 1, 2006 | 12:36 AM
rocket's Avatar
Originally Posted by 4runner46
....when I turn the radio on, the antenna goes up, but when it is fully extended the motor continues to run for about 15 seconds, grinding gears. Going down the motor stops fine.
Haha! Mine started doing the exact same thing yesterday! Ironically, i already bought a Tacoma whip assembly a few weeks ago. Now i just need some time to install it.
Search "Tacoma whip mod".
I'll never understand why anyone goes through the trouble and money to replace a crappy mechanism with the same motorized POS.... https://www.yotatech.com/forums/f2/cost-retractable-antenna-87721/
Old Jul 1, 2006 | 12:02 PM
4runner46's Avatar
Thanks for the help. I disconnected the power and left it up. If it breaks I'll definetely go for the whip antenna.
Old Jul 7, 2006 | 01:59 PM
cackalak han's Avatar
How do you disconnect it?
Old Jul 7, 2006 | 02:26 PM
Elton's Avatar
you have to take the stereo out and after you do that look for a box that say power antenna
Old Jul 7, 2006 | 03:31 PM
Cool. Thanks.
Old Aug 1, 2006 | 06:18 PM
97 BlueSR5V6's Avatar
I was going to disconnect the power at the antenna. Has anyone done that? Is it accessible from under the splash cover under the fender. Just trying to save time because it is hot as hell out.
Old Aug 31, 2006 | 07:53 AM
tthomas436's Avatar
Antenna Grinding Noise
I had the same thing happen to my 99 4 Runnner SR5 that happened to you. My old power antenna mast had a broken nylon gear cable and quit working.
I bought a replacement from Bridgewood Motorsports (www.antennamastsrus.com) and after I installed it, whenever the antenna would raise, after it reached its full height the motor would keep running for about 15 seconds and make a horrible grinding noise. I tried removing and reinstalling the antenna mast about 5 times and the grinding noise kept happening.
I contacted Bridgewood by e-mail, they said that once inawhile the nylon gear cable doesn't seat itself properly, and that if I returned the antenna they'd send me a replacement. I did, and they sent a new one with instructions to make sure the nylon gear cable had the teeth pointed towards the front of the vehicle when it was inserted. I did, and the new one has worked fine ever since.
Sounds like a teeth alignment problem.
Tom Thomas
The Woodlands, TX
montanatruck
Feb 26, 2017 07:07 AM
PlayAwhile
Jul 20, 2015 11:36 AM
Johntom240
7
Jul 13, 2015 12:18 AM
icentropy
Jul 11, 2015 07:21 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
