Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Quick Amp Installation Question
Old Jun 10, 2005 | 05:32 PM
Billabong's Avatar
Im about to hook up my amp and sub for my 99 4runner. I know i have the RCA's hook up into the headunit and go to the amp, but theres also a wire that i need to run from the stock wire harness to the amp... does anyone know which wire it is i need to splice into?? what color???
Old Jun 10, 2005 | 05:40 PM
Corey's Avatar
Co-Founder/Administrator
Not sure of the color, but I Googled 99 4runner remote amp turn on lead color and the first hit says you can use the electric antenna wire?
http://forum.ecoustics.com/bbs/messages/4/1235.html
I am also sure the answer is here somewhere on the forum too.
Here is some reading...
https://www.yotatech.com/search.php?searchid=851851
Old Jun 10, 2005 | 05:48 PM
Billabong's Avatar
thanks for your help. ive read through, but it seems as though, if i splice into the electric antenna wire, its only going to get power when the radio is on, not the cd player.
Old Jun 10, 2005 | 06:10 PM
Billabong's Avatar
could i just run it to a fuse that is activated only when the car is on? like the cigarette lighter fuse??
Old Jun 10, 2005 | 06:52 PM
DavidA's Avatar
Yes, it serves to notify the amp when the receiver is on so it will activate. You can put it on a switch or lighter, etc. Just remember it will run when power is applied to it and sometimes you don't want it on all the time.
Old Jun 11, 2005 | 05:32 PM
Billabong's Avatar
i got it all taken care of. i just tapped into the windshield wiper fuse and use the power from that.
thanks for all ur help.
Old Jun 15, 2005 | 09:46 PM
89macrunner's Avatar
your headunit should have a remote turn on lead thats what you want to use...that way your amp isnt pulling power for no reason if your radios off
Old Jun 16, 2005 | 09:38 AM
NisAznMonk's Avatar
wouldn't that mean that the amp would only turn on when it rains?
Old Jun 16, 2005 | 09:48 AM
96LtdYota's Avatar
no, your windshild wiper circuit has power only when the ignition is on... this works...
tj884Rdlx
Aug 28, 2015 12:04 PM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 17, 2015 10:13 AM
icentropy
Jul 14, 2015 10:23 AM
Coreyr384
Jul 10, 2015 11:13 AM
