Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
It is possible-2001 ex cab speaker install
Old Jul 25, 2012 | 06:26 PM
ThatGuy1295's Avatar
Looked through lots of threads and I don't see ext cab taco's with a custom built sub enclosure that allows for use of the rear seats. Don't get me wrong, theres lots of cool builds on this, but not very many with full functioning rear seats.
And pretty much the only way to do this with the proper air space for the subs is to modify the floor pan.
So this is what I built.
3/4'' mdf and about 6 layers of fiberglass on the bottom.
Little bit of bondo
Little bit of sanding
Lots of primer
And a multitexture paint, very cool IMO
End result is awesome. Its 2 10'' JLW1's with alpine 500w mono. Subs call for .625 air space and I've got about .6 and some polyfill to make up the difference. Sounds great, and only took about 20hrs ish.
Anybody else got pics of similar setups please post em up. By similar I mean any extended cab sub box that still allows for seat use.
Old Jul 25, 2012 | 06:55 PM
StewsRunner's Avatar
That is killer!! very creative
Old Jul 26, 2012 | 06:22 AM
James Woods's Avatar
Very nice work.
Old Jul 26, 2012 | 06:32 AM
rattlewagon's Avatar
I bet that feels funny when riding in the back.. Haha.
Nice work! Looks wicked clean!
Old Jul 26, 2012 | 08:02 AM
dropzone's Avatar
Fossilized
Very nice work. Pics with the jump seat down?
Where are you keeping the jack/spare tire tools now? Been awhile since I had a taco x cab, thought it went in the cubby under the rear d/s.
I am gomna have to check out you '89 build, I see some cool stuff
Old Jul 26, 2012 | 04:09 PM
Thanx
Oh ya almost forgot
Old Jul 26, 2012 | 04:12 PM
Ya there was some storage space, had to do away with that. Now I just keep everything i the toolbox in the bed. I would have kept it if it were possible.
Old Jul 31, 2012 | 08:56 PM
Soooo... Nobody on this site has done anything similar to this?
Come on..!!!!
Old Aug 16, 2012 | 10:53 PM
Checketts's Avatar
sooo.. the original storage compartments under the jump seats. how did you remove them? ive always wanted to do this to my '92. right now i have 2 10's in boxes sitting on the jumpseats
Old Aug 17, 2012 | 06:06 PM
Once you peel the carpet back youll see that the whole thing unbolts from the floor pan, leaving you with nothing there. But its still not enough, to get the air space and depth for the subs, youll have to actually "mod" the floor pan. And by mod i mean cut. But IMO its the only way to achieve this and still be able to use the jump seats.
You can kinda see where i cut the floor out in this pic. Wish I took one of the foor without the wood there.
Then you form tin foil into the holes and along the floor pan (make sure to tape your seams, you dont want leaks) and begin fiberglassing the bottom. Since its a perfect mold of the floor pan it plugs the holes you cut. I used some caulking apon installation around the perimeter of the holes. The box is glued to the floor and is sealed off from outside.
Then I made a heat shield for the exhaust becuase its about 3 inches from the bottem of my box.
If you can imagine that picture without the top peices of wood it would just be sides. Thats where you start with your fiberglass. Basically building the bottem half of the box in the truck, then you can remove it and finish it outside the truck. Once its out of the truck you can do a lot better job of making sure its airtight, and very solid (the bottom needs to be an 3/16''-1/4'' thick of fiberglass). Or at least thick enough to where you cant flex any portion of it by pushing hard on it with your thumb.
Its a big job IMO, had to remove the interior of the truck, precautions need to be takin so that you dont get fiberglass spills in the cab, building the box can be very time consuming and theres lots of steps, then there installing it whens its all done, its pretty heavy and big and if you measure everything right it should fit pretty snug.
Im not the best at explaining and wish I took more pics, but any questions feel free to ask.
I hope to see somone else pull this off.
Old Nov 2, 2012 | 08:45 PM
Almost forgot to finish this. You have to do something about those pesky bench seats being push through.
Some plexi and your solid.
Old Dec 10, 2012 | 06:18 PM
UnderFire's Avatar
I would've aimed the subs down, just so they would be hidden and not firing into the bottom of the seats when you had passengers.
Old Dec 11, 2012 | 07:27 AM
But then they would be muffled sounding and have the wrong air space, becuase the hole cab would be the sub box, not just the sub box. Subs work the best with the proper air space (behind) them. The subs that you do see aimed down, such as home theater systems, are still in an enclosure but pointed at the floor with a few inches of space between the floor and sub. And theres no way theres enough room in the back seat of a tacoma for that setup while maintaining rear seats, atleast not done right. Especially considering I had to modify the floor pan just to get enough air space. Unless you want to buy $800 shallow mount subs , then you can mount them in your ashtray upside down. And I rarelly have passengers, just wanted to keep the capability. When I do have passengers I just shut them off or turn them way down.
Old Dec 11, 2012 | 07:43 AM
This might explain better.
Old Jun 26, 2016 | 08:22 PM
85yodaman's Avatar
where did you put your amp?
Old Oct 20, 2022 | 10:08 AM
Austin223556's Avatar
what are your dimensions
young buck
18
Aug 27, 2018 02:40 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
coleypull15
Nov 3, 2015 07:41 AM
mtb_taco
Jul 15, 2015 08:36 AM
bryan34w
Jul 6, 2015 05:53 PM
