What kind of welding class should I be taking?
Old Jan 4, 2012 | 08:41 AM
  #101
4Crawler's Avatar
I found the classes I took to be very useful as well. Highly recommended to take before you invest in your own welding equipment as you can find out the different welding processes and also what the different features are good for. Also you can find out what process(es) works well for you and the type of welding you think you'll be doing. For example, I first got into a regular arc (SMAW) welder and knew for sure I wanted to get both AC and DC capability. Most of the lower end machines are AC-only and you lose a lot of capability without DC mode.
There were quite a few folks in the classes I took that basically took the class just as an intro. and to find out the ins and outs of the various types of welding before they invested in their own machine. And not all of them came to the same conclusion. One woman decided that gas welding was for her, she was more into artistic projects and a oxy-acet. torch was the best tool. I went first with arc, then MIG and a TIG welder, since they all have their place. And it was certainly less expensive to burn up the schools rods and gas and scrap metal learning that going out and buying your own supplies. I figure it costs about $30/hr. to run my MIG with the wire and shielding gas and in class, we ran those machines 3 hrs./night twice a week for the whole quarter.
Old Sep 7, 2012 | 01:54 PM
  #102
bryanR060's Avatar
Originally Posted by Philbert
Hi guys,
I'm looking for the lowest cost to use, and preferably the easiest to learn. Are any of the welding styles "too weak" to handle what I want to do or will they all suffice?
Thanks for your input guys!
Phil
You can go to a welding class that teaches the basics first. They probably will also have some overview of the different types so that you can choose on which one you would like to learn further. It is always better to learn the basics first so that learning further will be easier. Good luck.
Old Sep 7, 2012 | 04:43 PM
  #103
Philbert's Avatar
Thanks - I took a welding class at Techshop in San Jose last summer (after I started this thread) and it was extremely helpful. I have since bought a flux core welder (HF) but not yet used it - too many other projects got in the way....
Old Sep 7, 2012 | 04:51 PM
  #104
Teuf's Avatar
Hint, clean real good whatever you weld, dirt, rust, mill scale. And have a good clean ground point. And experiment with settings. The guide inside the machine is just that, only a guide. good luck
Old Sep 7, 2012 | 04:55 PM
  #105
Philbert's Avatar
Thanks Teuf!
This sounds like a no brainer, but always disconnect your battery when welding on the truck right?
Old Sep 7, 2012 | 08:46 PM
  #106
Teuf's Avatar
I have seen welds done with it attached. Ground close to the weld not just anywhere.
Old Sep 7, 2012 | 08:48 PM
  #107
Teuf's Avatar
But then again there is no harm in disconnecting the batteiy
Old Sep 8, 2012 | 09:54 AM
  #108
Philbert's Avatar
Yeah, I once welded with the battery still connected - I cross jumped my truck in the dark in the rain I think I'll be disconnecting it regardless of where I weld on the truck
Thanks!
PS - dumb question - can you flux core weld both steel and aluminum, separately, using the same flux wire?
I've heard of TIG welding for aluminum, but don't know what you can/can't do with flux core in regard to Aluminum?
Old Sep 8, 2012 | 10:12 AM
  #109
4Crawler's Avatar
I weld on my '85 with the battery connected most of the time. Use DCEP and keep the ground as close to the welding location as possible. I need to use that setup when using the on-board (alternator) welder as you have to have the engine running to power the alternator.
Flux core for aluminum is apparently only used for brazing in a oven and for sure you can't use the same wire:
- http://weldingweb.com/showthread.php?t=22621
You can get aluminum arc welding rods and you can do aluminum MIG with shielding gas. In my welding class, the aluminum MIG machines were different than the steel MIGs, you need bigger dia. wire and spool guns since it it hard to push the soft alum. wire through a long cable and gun like you do with steel. Also, you generally need to use a separate gun anyway as the aluminum wire would pick up steel wire residue if use in a gun once used for steel and that would contaminate the weld. In my class, we typically used TIG on thinner aluminum and spray arc MIG on thicker stuff. (like 3/8" and up)
Old Oct 16, 2012 | 11:08 AM
  #110
Philbert's Avatar
Quick Question for you guys....
So I posted up this thread last Fall when I set up my welder (before getting distracted by my transmission grenading).....Now I'm ready to revisit the welder.
Wife has a contractor coming by today to quote out installing some new sockets in the house, including a 220 in the garage for me (yay!). I need to know what to have her tell him to set up/quote out.
I believe I'll want to have him install a 50A breaker/receptacle, right? The Dryer is 30A, and I had initially planned on using that, but now that I'm getting my own in the garage I want it done right. Is there any reason NOT to do a 50A breaker/receptacle for a 220V Flux Core welder?
Here is a link to a write up I did (with photos) when I installed my plug/cord to the welder. You can see the Leviton (Home Depot sourced) plug I installed and that it has the "L" shaped prong at the top; the kit came with another prong (more a "V" I think...) that I can use instead of the "L" - I still have it. Question is, should I have them install a receptacle to fit the plug I have (originally for dryer), or do I need to replace the top post, or...do I need a different plug adapter on the welder's cord?
I need to know this afternoon please
Thanks guys!
Old Feb 9, 2013 | 05:25 PM
  #111
skoti89's Avatar
thread revive! I'm thinking about taking a welding program to. I can do just about anything I want on my 4runner except weld. I've never paid any one to work or do anything on my rig except for an alignment.
Butte Community College here in nor cal has a 1 year welding program for certificate. I already have 50 credits of GE so im thinking about going the the associates degree. It's really wierd, Im doing the auto program, but I dont want to be a mechanic my whole life. I'm going to do the welding program, but I don't think I want to weld as a profession(unless I get into a specialty like pipe line welding). But throw those two things together and I could eventually follow my dream of opening my own 4x4/fabrication/general auto repair/ smog shop. Or just work for shop mostly doing 4x4 fabrication.
Old Feb 9, 2013 | 06:17 PM
  #112
Teuf's Avatar
Way to go. I will have my A.S. in welding come spring. I am older but I am optimistic about work. Good luck.
kgcwb44
Jan 29, 2023 10:02 AM
jasonty
41
Dec 23, 2018 01:00 PM
young buck
18
Aug 27, 2018 02:40 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
crashburnoveride
Jul 10, 2015 06:39 AM
