welding my bed
Old Feb 3, 2007 | 05:54 PM
killa b's Avatar
welding my bed
ok im trying to weld my bed back together after cutting it to bob it and ive got a stick welder and i tried to turn it to its lowest setting and im still just welding right through the metal so what welder do i need to use and what kind of welding wire or rod do i need thanks
Old Feb 3, 2007 | 06:09 PM
hamstrungtaco's Avatar
buz bozz will work with .023 wire
Old Feb 3, 2007 | 06:31 PM
killa b's Avatar
will a wire feed work
Old Feb 3, 2007 | 06:57 PM
Dan_90SR5's Avatar
A TIG would be your best bet, but most of us can't afford one or feel there is no real need for one with most welding projects. With that said, a MIG is your next bet. What I tend to do when welding sheet metal it to make tack welds about 6-8" from eachother. Work all the way around the panel. Then start over with tack weld half way between the first ones. Repeat this process until the panel is completely welded. Make sure that the welding area stays cool. This will keep the part from warping and give you great results.
Old Feb 3, 2007 | 07:41 PM
killa b's Avatar
thanks man and im new to welding what is a mig welder all i know is the genaric names so u can rag on me all u want but hey im tryin to get started on fab work and just tryin to do it right
Old Feb 3, 2007 | 07:44 PM
ADH8796's Avatar
Mig will work but Tig will be the stongest. If you don't put a peace of slightly thicker metal behind the two peaces that you are trying to weld together than it will be hidden on the inside of your bed and you should be able to weld it up without too much of a problem.
Old Feb 3, 2007 | 07:49 PM
killa b's Avatar
ok ill give that a try
Old Feb 4, 2007 | 08:25 AM
Dan_90SR5's Avatar
That would work if you are going to use the arc welder, but not needed with quality welds made with a mig or tig.
As I said, tig is best, but not really an option for most of us.
killa b- to answer your question, a mig welder is a wire feed welder that uses either flux core wire or solid core wire with a gas shield.
Old Feb 4, 2007 | 08:32 AM
killa b's Avatar
ok thanks and i can get a hold of on of those so ill give it a try and see what happens
Old Feb 4, 2007 | 12:12 PM
Elkaholic's Avatar
Dan was exactly right. And I agree, however Tig is only gonna work best if he can properly weld it which isnt very successfull being new to welding. Very hard to master. Anyways yes try to get a mig welder and if at all possible a new machine which can do pulse welding. Thats gonna be your best bet for the thin stuff. Even without the pulse. And times 2 with the .023 wire.
Old Feb 4, 2007 | 04:21 PM
killa b's Avatar
yea went and got a mig and its working just the wire in it is old and not the best it came with the welder and the wire is .030 but my cuts wernt straight at all so i need to cut out piceses and weld them in so just hope i can fix it thanks for the info
Old Feb 5, 2007 | 03:18 PM
Gerdo's Avatar
Killa we need pictures!
Old Feb 5, 2007 | 04:45 PM
Elkaholic's Avatar
is it core flux wire? or standard wire and using gas?
Old Feb 5, 2007 | 07:21 PM
killa b's Avatar
i belive its flux nit sure and its a non gas wire feed
Old Feb 7, 2007 | 09:25 AM
ADH8796's Avatar
yeah that's flux core works great though
Old Feb 13, 2007 | 05:29 PM
dfoxengr's Avatar
mig would actually be better so you dont warp it.
justdifferentials
14
Jun 11, 2017 08:36 PM
irv
Sep 23, 2015 08:30 AM
runnermedic
13
Sep 21, 2015 05:20 PM
sonorn67
Sep 19, 2015 05:39 PM
