update on rednneck bumper
Old May 4, 2007 | 06:01 PM
jakindle's Avatar
small update getting a free arb compressor set up compressor solenoids wiring etc free from my buddy said he could get enough air out of it to make it worth him time for on board air he had no tank just compressor
yeah for me
here are some new pics of my rig
added the air fitting to see if she would hold ...... no problems put in 200 psi to see if the endcaps would blow off while standing back bout 25 feet
let the air out now will wait and see what other fittings / plumbing ill need
when i get the arb setup
cant wait been looking at train air horn to really get em to scatter the bumper and the flat black rattle can does a good job of that now
also lincoln lock the rear the same way that they did here
http://www.ih8mud.com/tech/woody/welded.html
and added 2 pieces of round stock on the spider gears sorry no pics not touching my $ 1500 digital camera while covered in gear oil
Old May 4, 2007 | 11:36 PM
Elvota's Avatar
I looked up "F'n Stout" on Wickepedia and was linked to this thread instantaneously.
Old May 5, 2007 | 05:56 AM
Stomis's Avatar
So what happens when that tank is full and you say... get in an accident or hit a tree in the woods and it gets a good enough dent to throw the volume of the tank off that bad?
Old May 5, 2007 | 10:35 AM
BruceTS's Avatar
Built-in air bag system
Old May 5, 2007 | 02:52 PM
914runner's Avatar
Rednecks dont think of that kind of stuff! And depending on how think the tube is, and how strong the welds are, its a pretty small chance the tank will blow.
Old May 5, 2007 | 02:59 PM
crackerjack's Avatar
Blow up...that only happens in the movies,
That bumper and cockroaches will be all thats left after the nuclear exchange ha ha
Old May 5, 2007 | 03:52 PM
yotasavg's Avatar
that's a pretty crazy bumper. i really like it. what are the specs on the metal?
Old May 5, 2007 | 04:07 PM
91TPU's Avatar
and yota's
Old May 11, 2007 | 06:04 PM
jakindle's Avatar
Thumbs up
as far as specs kinda what i had laying around or from a buddy
the tube is 6inch pg&e gas line that i got from a buddy stout as hell measuring the tube it is 1/4 " thick wall
the brush guard was of a small truck bolt on type (not any more ditched the bold and welded it up )
the reciever hit was off of a full siize pickup drawtite version cut to fit
the end caps are also 1/4" thick 4 beads welded and ground smooth to ensure airtight seal
the d rings 5/8 round spec are 12000 pound working load dont know the breaking load guess i will find out
holds air pressure good plan on getting a presure releaf valve when i wire in the arb compressor
plas for the tank are airing tires and air train horns
and as far as hitting something cant wait
the paint job is a lowes special .98 cent flat black sanded off the toyota stick crap and sand the paint to scuff it up the cab took six cans
easy to fix if i scratch it
even with a welded rear diff (temp) will be my spare the spooled third is being built
it is pretty tam on the pavement except in a parking lot inside tire drags
as far as cornering and bumpy roads it seem to be more predictable the the open dif (note i have had both a locker and a spool in other vechiles)
justdifferentials
14
Jun 11, 2017 08:36 PM
86 87 4Runners
Nov 20, 2015 07:46 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
