My Camping Trailer Project
Old Sep 4, 2010 | 05:17 AM
  #61
coops2k's Avatar
like it, nice work - subscribed
Old Sep 4, 2010 | 07:28 AM
  #62
Ardent's Avatar
Originally Posted by ScottyC
Fill out the paper. Walk in, hand it to the clerk. They will ask you what you spent building it (I said $150). What is it Worth? (I Said $150).
I paid $14 and walked out with a plate and a small VIN plate that attaches to the frame. No inspection, nothing. Piece of cake.
Down here (El Paso County) they make you fill out a form and provide receipts for all the materials used to build the trailer.
Looking good for sure!
Old Sep 5, 2010 | 06:23 PM
  #63
DIRTCO's Avatar
Thanks for the info! I plan on talking to the DMV in the next week or two, I really hope it goes better than every other time I've been there.
Old Sep 5, 2010 | 06:34 PM
  #64
broncrider's Avatar
wish they all could be the same. i know here all you do is going in and get it inspected by a local shop and they right you a paper saying it has all lights and they work. then you take the paper into the dmv and they give you a plate
Old Sep 5, 2010 | 07:17 PM
  #65
DIRTCO's Avatar
It's really hard to work on the trailer without being able to roll the thing around, so I decided to get the axle and suspension figured out before I work on anything else.
Several weeks ago I tried to order a complete axle from a shop that builds custom trailer axles and that I've heard good things about. After several calls, over a couple days, I couldn't get a hold of them and I decided to save some money and build my own.
I had a section of 2x2" 1/4" wall square tubing, and wanted to build the axle using it (while the trailer should be pretty light, I would like for the axle to take a rock hit or two without bending). After a LOT of research I found some 1 1/2" square spindles that would fit some 6x5.5 hubs.
Old Sep 5, 2010 | 07:42 PM
  #66
DIRTCO's Avatar
Together the hubs have a 3500 pound rating, with the heavy wall axle tube the trailer should be able to see some moderate terrain without an issue.
First I chopped the tubing to size
I had to clearance the spindles for the welded seam inside the tubing, then beat the crap out of them on a wood block to get them seated. I left a little room to weld them without getting into the sealing surface and I covered the spindles with aluminum foil to protect the sealing surface.
  #67
broncrider's Avatar
were did you get those at? and also how do you keep all your pens? all mine always get stolen off my box hahah
Old Sep 5, 2010 | 08:06 PM
  #68
DIRTCO's Avatar
Once I got the spindles welded up I got to work on the spring perches. I cut some square tubing in half, then notched it for the axle tube and welded it together.
Then I greased the bearings, installed the hubs and painted the axle.
Old Sep 5, 2010 | 08:24 PM
  #69
dropzone's Avatar
Fossilized
as always, nice work
I like the route you went with the axle, wasn't sure if your were gonna with a Toy axle or not...
Old Sep 5, 2010 | 08:52 PM
  #70
Tofer's Avatar
Sponsor
Your going to cost me a bunch of money.... I wanna build one now.
Old Sep 6, 2010 | 04:23 PM
  #71
DIRTCO's Avatar
Thanks!
Yeah, me too. I will go to the DMV in the next week or two and see what is involved. Everytime I go to the DMV I swear they are out to get me, it's always a total PITA.
Trailerpart.com, I can post the part numbers if anyone is interested. As for the pens, those are the crappy ones that suck and I don't use!
Old Sep 6, 2010 | 04:39 PM
  #72
DIRTCO's Avatar
Thanks! I thought about using a Toyota axle but I didn't for a couple reasons. First, I don't know if they are legal; I've been told that they are not legal in Colorado any more. (Just hear say)
But, for the most part it was weight, diff clearance and less rotating mass. A strong trailer axle seemed like a better idea all around.
Old Sep 6, 2010 | 05:21 PM
  #73
DIRTCO's Avatar
If you plan out your parts it's not that bad, but it does add up fast!
Old Sep 7, 2010 | 05:14 AM
  #74
cootees's Avatar
Love it. Post up those part numbers if you don't mind.
Old Sep 7, 2010 | 05:41 AM
  #75
irab88's Avatar
subscribed
i'm a fan. lovin' them pics
Old Sep 11, 2010 | 07:20 PM
  #76
morena67's Avatar
- Fan two...!
Old Sep 11, 2010 | 08:00 PM
  #77
BigBluePile's Avatar
Dirt, again, another freakin awesome build!!!
Old Sep 13, 2010 | 04:45 PM
  #78
Dgfriend707's Avatar
subscribed
Old Sep 13, 2010 | 05:26 PM
  #79
DIRTCO's Avatar
Thanks! I'll round up the part numbers when I get time.
Old Sep 13, 2010 | 05:35 PM
  #80
DIRTCO's Avatar
Originally Posted by irab88
subscribed
Originally Posted by morena67
- Fan two...!
Originally Posted by Dgfriend707
subscribed
Thanks guys, I really appreciate the kind words!
