My 7M-GTE build
Old Aug 7, 2006 | 05:27 PM
slacker's Avatar
My 7M-GTE build
so look what I got back earlier last week .
time to get going on the build ...
rings are Altrom ... water pump is Nissan :-X ... rest is OE.
first coat of primer ...
Old Aug 7, 2006 | 05:28 PM
slacker's Avatar
not to many people tackel the dreded "oil pump drive shaft bearings" .. I did
slacker's Avatar
so.. got the short block assembled ;D ..
Crank in
installing ARP bolts , rings , and rod bearings
I have a short block ;D
and front cover
more tomorrow .
Old Aug 7, 2006 | 05:49 PM
Cebby's Avatar
Nice progress! Looking good!
How you going to handle the cooling/radiator? I know that is one LONG motor...
Old Aug 7, 2006 | 06:31 PM
slacker's Avatar
well so far a supra rad for cooling ...
Old Aug 8, 2006 | 01:30 PM
4RunnerKid's Avatar
you going to cut out the core support for clearance or move the motor back a little? looking great so far. keep up the good work.
Old Aug 8, 2006 | 04:18 PM
slacker's Avatar
actually its going into a 2wd .. with a full custom frame .
I'm going to move the engine back 2" and cut the fire wall , and tunnel .
Old Aug 8, 2006 | 04:19 PM
slacker's Avatar
so a little bit more today ..
got the pan on ... of course it came with a cork gasket that i'll never use .
and some of the accessories ..
MLS head gasket in place , and new ARP head studs .
and the head goes on , and torqued to 80FT lbs
back cover and set the valve covers on for effect .
and almost done ...
so thats it for now ... I had to order the turbo oil pipe gaskets .
Old Aug 12, 2006 | 08:23 PM
slacker's Avatar
did a little more today ...
got the valves adjusted , and cams in
and bolted on the covers , new thermo , cam seals ......
also started on the RC - 550's
400 Horses , here I come
Old Aug 13, 2006 | 06:42 PM
slacker's Avatar
so .. more .. ;D
fuel rail is buttoned up , and also center gasket
timing gears are installed "correctly" and belt installed .
also thermo housing .
exhaust manifold , and shields .
front cover
and the upper intake ..
just about done .
Old Aug 14, 2006 | 02:48 PM
dwh91102's Avatar
Looking good man!!! Keep up the good pics.
Old Aug 14, 2006 | 03:43 PM
slacker's Avatar
thanks ...
Mostly done .. I just have to add a few of the accessories ..
Old Sep 13, 2006 | 10:33 AM
brandontrek's Avatar
sweet biult....on my dream list is to learn about tearing engines down and biulding them back up so i can get a 7M-GTE and toss it in my lil yota....ahh the look on ppl's faces when i drive by them and they hear a nice "psss"
kawazx636
Oct 6, 2021 03:03 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
smilen724
13
Nov 8, 2015 04:11 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Toys4parts
Sep 26, 2015 01:56 PM
