My 7M-GTE build
My 7M-GTE build
so look what I got back earlier last week .
time to get going on the build ...
rings are Altrom ... water pump is Nissan :-X ... rest is OE.
first coat of primer ...
actually its going into a 2wd .. with a full custom frame .
I'm going to move the engine back 2" and cut the fire wall , and tunnel .
so a little bit more today ..
got the pan on ... of course it came with a cork gasket that i'll never use .
and some of the accessories ..
MLS head gasket in place , and new ARP head studs .
and the head goes on , and torqued to 80FT lbs
back cover and set the valve covers on for effect .
and almost done ...
so thats it for now ... I had to order the turbo oil pipe gaskets .
and almost done ...
did a little more today ...
got the valves adjusted , and cams in
and bolted on the covers , new thermo , cam seals ......
also started on the RC - 550's
400 Horses , here I come
so .. more .. ;D
fuel rail is buttoned up , and also center gasket
timing gears are installed "correctly" and belt installed .
also thermo housing .
exhaust manifold , and shields .
front cover
and the upper intake ..
just about done .
front cover
just about done .
sweet biult....on my dream list is to learn about tearing engines down and biulding them back up so i can get a 7M-GTE and toss it in my lil yota....ahh the look on ppl's faces when i drive by them and they hear a nice "psss"
kawazx636
Oct 6, 2021 03:03 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
smilen724
13
Nov 8, 2015 04:11 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Toys4parts
Sep 26, 2015 01:56 PM
