I've got a new cheaper plan!
Old Mar 3, 2005 | 05:35 AM
  #201
sschaefer3's Avatar
I guess I won't hold my breath. It would be worth it, but unless you have been there, you won't realize it.
Old Mar 3, 2005 | 05:36 AM
  #202
ravencr's Avatar
Originally Posted by RobT2k
Hey chris- Does your limited have the little 4x4 button on the side of the transfer case shifter?
Yes, it's on the left top side of my 4wd shifter.
Do you have the "multi-mode" 4wd option that came on some/all? of the limiteds?
I don't know what the difference is.
If so, have you looked into whether or not we can do the "junkyard hub swap" from a tacoma with manual hubs for our ADD ones?
Does anyone know?
I understand there is more work to make the ABS operate, but will the extra bells and whistles on the limited edition stop us from going to manual hubs?
Honestly, I could care less if I have ABS anymore, since I rarely drive it anymore, and it's mostly off-road. So, the question, is it possible to do it the way you mentioned?
Chris
Old Mar 3, 2005 | 05:37 AM
  #203
bamachem's Avatar
If the have the push-button the shifter, then you have multi-mode.
Old Mar 3, 2005 | 05:41 AM
  #204
ravencr's Avatar
So does that mean there's a cheaper way to go to manual hubs than the way Steve did it before?
Chris
Old Mar 3, 2005 | 05:57 AM
  #205
ravencr's Avatar
Originally Posted by sschaefer3
Well you can't really short notice me and cheese, you really need to make the call here in the next week or two or forget about us being there. He has to arrange time off work and I have to find a place to stick the kids.
When exactly is this? What dates? Think of all the cash you saved on your new cheaper plan. You gotta see if it will work.
Also budget in at LEAST 2 spare front axle shafts. No you can't buy them in Moab, I bet.
Let me know soon or we won't make it.
I completely understand. Let me see what I can do, talk to Joe Darlington, and see what I find out.
I know you guys are mocking me about the title of this thread. I actually should probably change it, but my plan is working out great so far. I wheeled it on the 19th with the 3" body lift and the 3" drivetrain lift, and it worked just as it did in the past.
If I do go out there, I would definitely have some spare axles.
I'm sorry I don't have an answer yet, but I'll let you know by the end of next week, fair enough?
Chris
Old Mar 3, 2005 | 06:02 AM
  #206
bamachem's Avatar
Chris
no. it just means it has a "selectable locking center differential" instead of the regular 4WD that splits the power/torque 50/50 front to rear. w/ the multi-mode pushed in, the center diff is unlocked and the rig is really in "ALL WHEEL DRIVE" so you can drive it on pavement. When the shift lever is in 4HI, then it's in 4WD-HI and the center diff is locked and should only be used on loose surfaces to allow for tire slippage.
Old Mar 3, 2005 | 06:07 AM
  #207
ravencr's Avatar
No, that's not how mine is. I have the 4wd button that I just push to go into 4wd, and then I slide the shifter forward to put it in 4-lo. I don't have an awd, 4-hi, and a 4-lo.
Chris
Old Mar 3, 2005 | 06:15 AM
  #208
bamachem's Avatar
Chris
hmmmm...
i have the button that i use in 2HI to go to "Multi-Mode 4WD", then I can shift to 4HI, then to N and on to 4LO...
Old Mar 3, 2005 | 08:45 AM
  #209
ravencr's Avatar
hmmmm...
I can't remember the year, but I think the 1998's were the first year for the multi-mode you're talking about. Mine is a 1997, and it's always in the 4hi position, but it's only in 4wd when I push the button. Then if I want to put it in 4-lo, I can put the vehicle in neutral, and then push the shifter forward all the way into 4-lo, which actually works with or without the button pushed.
Chris
Old Mar 3, 2005 | 09:14 AM
  #210
loosehead's Avatar
Hmmm, allow me to confuse the issue even more...My '98 SR5 has no buttons, and 4 positions on the T-case shifter 2-Hi, 4-Hi, N, and 4-Low.
Old Mar 3, 2005 | 09:29 AM
  #211
bamachem's Avatar
that's the manual transfer case w/o the push button bells and whistles.
that's typical for an SR5
limited's got the push buttons and in 98+ got AWD to boot!
chris's has 3 manual positions + the button.
4hi disengaged button = 2wd
4hi engaged button = true 4wd
Neutral
4low
my 99 has:
2hi
2hi + the button = all wheel drive w/ center diff unlocked
4hi = true 4WD w/ center diff locked
Neutral
4lo
to add to that, my ARB rear locker can be engaged/disengaged in any of those...
Old Mar 3, 2005 | 09:47 AM
  #212
loosehead's Avatar
Ah, yes...I overlooked the fact that Chris has a limited. That all makes since, Andy. I've never spent much time in any Ltds.
Old Mar 3, 2005 | 01:12 PM
  #213
ravencr's Avatar
I didn't think I was crazy!
Chris
Old Mar 3, 2005 | 04:22 PM
  #214
Bighead's Avatar
Total Est. Time: 25 hours, 53 minutes
Total Est. Distance: 1689.91 miles
One HELL of a road trip.
2 days to get there. 2 days to get back. 200 gallons of gas for the roundtrip.
C'mon Andy, I did the Moab trip in October...but I started/finished in North Carolina! And yes, it is one hell of a road trip. Yet another reason to drop the S/C and go back to 87 octane.
Old Mar 3, 2005 | 04:59 PM
  #215
seaflea's Avatar
This is totally off subject , but me and Mikeys87 are talking about taking a trip out there within the next 2 years. We are planning on taking at least a week off to go. Maybee we shoud get a caravan together to make the trip!
Old Mar 3, 2005 | 05:02 PM
  #216
redplastic2p3t's Avatar
im thinking of going summer of 2006 i recently acquired a tow rig (91 f250) so im a gonna keep looking for a trailer now and with the recent and hopeful change in occupations i think i can make this happen!!!
Old Mar 3, 2005 | 08:01 PM
  #217
sschaefer3's Avatar
Chris
Ok, let me know in a week. If you go, you'll want us there. It's wise to have a good group in Moab. To help you out if you run into trouble.
Old Mar 4, 2005 | 02:33 AM
  #218
ravencr's Avatar
Thanks Steve! I'll definitely let you know.
Chris
Old Mar 20, 2005 | 07:48 AM
  #219
ravencr's Avatar
If anyone that's been following this thread is interested in following my gas tank relocation details, go here: https://www.yotatech.com/forums/show...296#post561296
I've finally got the tank, and I'm beginning the project this week.
Chris
Old Oct 5, 2005 | 01:41 PM
  #220
ravencr's Avatar
I'm replying to this thread, because there's so much love about this thread title. But, for those interested in doing a drivetrain lift, I just bought 1' of 3x2x3/16" tubing and 3' of 3x1.5x3/16" tubing to make a custom front crossmember that will mount to the stock location rubber mount. This setup will most likely not work for those wishing to do a SAS, but for most of us, when combined with a 3" body lift/drivetrain lift, it results in a crossmember that rests 1/2" above the bottom of the frame rails, clears the bottom of the front driveshaft, and leaves you with a crossmember that won't hang you up on obstacles anymore.
I haven't tested it out of the trails yet, but I'd say that if you're hitting this front crossmember, you're probably running trails that our vehicles aren't capable to run anyway.
I'll begin the installation tonight with hopes of finishing it, but I'm also doing some welding for a local guy needing to weld on some shackle hangers on his front bumper.
Hopefully, I'll have pics in the next couple of days.
Chris
