Fillsrunner4.3 crawler (PART TWO) - pic heavy!
Old May 6, 2009 | 12:14 PM
  #241
fillsrunner4's Avatar
Originally Posted by 904_runner
DO IT!!!!!
You got 16 days!
LOL
Well then, puttin the pressure on now thats for sure.
Ill let ya know
Old May 6, 2009 | 12:17 PM
  #242
904_runner's Avatar
Good luck man.
I wish that gets done soon.
I was going nuts when i couldn't drive mine for over a month.
Old May 6, 2009 | 12:19 PM
  #243
one of these days it will be out of just being my dreams again. thanks me too
Old May 10, 2009 | 11:31 AM
  #244
Some updates...
Did a little body work this weekend. Closed the beds inner panels with some dimond plate I got for free awhile back. Thought it would look pretty cool I closed both sides but only have a picture of the one side.
Added some hinges to both sides or my tailgate
Was a nice day out so I wanted to work outside
Coolant lines are pretty much done. Just have a few more solders to do and have to wait, or make an adapter to mate the 1.5 coolant lines to 1.25. and pick up some radiator hose from the store too. Im lazy
Pass side
Pass side in the bed of truck. has a little bit to change here but get the point
Looking back Pass side
Under the body Pass side
I tried to make the lines with as little bends and as straight as possible in hopes my water pump has the ability to push the new increased amount of fluid through the system. I may have to add in an electric pump on the radiator side if I have issues but Ill just have to wait and see on that.
The drivers side pics are uploading but Ill have them up in a few mins here.
Old May 10, 2009 | 11:48 AM
  #245
Ok so the drivers side lines.
I still have to add in the reducer here. I bought one from summit with a radiaor filler so to help with filling and bleeding the system. my lines will run just above that little blue filter in the picture
I wanted to keep the lines close to the body.
Fit really nice here. and still has great distance away from the exhaust
And added some more rediculous plate to the front of my frame. its 1/4" and will be a great base to my future winch
Next comes the wiring and hopefully cage too
Old May 10, 2009 | 05:32 PM
  #246
took a few more pics today.
Hung the reverse lights and shows the diamond plated bed finished on both sides. I think it turned out really clean
Had a package up at my parents house from summit today while visiting with the Mother too
My filler with reducer 1 1/2" to 1 1/4".
I know I havent had to many recent front shots so heres one to wet your appitite
Old May 13, 2009 | 01:52 PM
  #247
904_runner's Avatar
FILL DRIVE THAT SUCKER AROUND NOW!
we all want to see it driving.!
Old May 14, 2009 | 12:39 PM
  #248
Wiring starts this weekend... Well today actualy after work actualy
Will see if I can get video when it fires and drives
Old May 14, 2009 | 03:33 PM
  #249
YeloSub7's Avatar
lookin good as always...
Old May 14, 2009 | 03:35 PM
  #250
Thanks dude
Will look better with some tube and runnin one step at a time lol
Old May 19, 2009 | 06:05 PM
  #251
Ran around most the weekend doing this and that, mounted my battery and did a little wiring.
Put the dash bezel back in
Left long leads off the ignition plug so I will be able to use my key to turn on the motor
Didnt really get the chance to do much more to mine like always
Biggest thing tackled this weekend was the lifting my friend erics truck.
was 2wd now SAS with 4.7's 5.29s, locked rear and some 35's. Gonna be his DD thats capable to go pretty much anywere
The springs are 4x4 rears, and 4x4 rears upfront with some long shacles Bout 6" I think they were
So easy top cut off 2wd brackets compared to 4x4 IFS
Cut front frame suport to allow for the new beefy home built front crossmember
The truck previoulsy had no power steering but we have a box to go in and are just waiting on a flat pitman arm
Tires sit very far forward which is perfect. Very little triming to do here
Front view right now. Still have some body to put on and the bed.
Shortend the frame to the crossmember. Need to bob the bed and add shocks.
Very clean
More on mine to come but in the mean time some eye candy
Old May 19, 2009 | 07:11 PM
  #252
TOYOTA 1's Avatar
nice..
ruf right? whats the specs on the leaf packs?
Old May 20, 2009 | 07:59 AM
  #253
Originally Posted by TOYOTA 1
nice..
Yup the fronts are stock rear 85 4x4 ex cab leaf springs and the rear are 90-95 excab rear springs. All the lift comes really from the 6" shackles. the front crossmember was cut out for the new hanger. custom tubes were made to go through the frame for the front shackles. the rears front hangers were used in there stock location. the 2wd rear springs were longer than the 4x4 so shackle mounts were made for the rear and the frame section just infront of the very back crossmember was cut off. we drilled the perches and top plates in the rear to move the axle ~1" back
Old May 20, 2009 | 08:10 AM
  #254
904_runner's Avatar
PHIL!!!!!!!!!!!!!!
Wheres the eye candy of the 4runner? I want to hear your opinion of that new 4.3!
Old May 20, 2009 | 08:15 AM
  #255
PHIL!!!!!!!!!!!!!!
yeah I know oh and the 4.3 IMO even in the not wired up state right now blows the 3.4 out of the water Ive got a 4day weekend coming up and my time is going to be into doing just that. Had some coolant line leaks I have to fix and im gonna get my ignition wired this weekend. No jinxin me
Old May 20, 2009 | 08:22 AM
  #256
904_runner's Avatar
SO you have driven it though? NICE
Yea im really digging the 3.4 i put in. Much better than the 3.0L.
Old May 20, 2009 | 08:31 AM
  #257
havent driven it yet but have seen many a driven the 3.4 was nice when it ran for me.
Old May 20, 2009 | 08:35 AM
  #258
904_runner's Avatar
Yea i like it.
I was on the highway in my mom's stock 99 2runner with the 3.4L automatic, and my buddy was driving next to me in his brothers 2000 (iirc) chevy pickup 4.3L manual 2wd.
The 3.4 was a bit faster than his though, might have just been the difference in our driving styles, im an aggressive driver, and i don't know what he was revving up to, etc..
I would like to hear what you think in the 4runner what motor feels better in your opinon. 3.4 or 4.3! Get this done so i can know the troof!
Old May 20, 2009 | 08:42 AM
  #259
Ill let you know for sure but I think I already know
Old May 20, 2009 | 08:43 AM
  #260
904_runner's Avatar
yea i feel like i know too.
That darn 3.0L will beat both of them hands down in a race.
