Dual T-case with custom 3 stick shifter
#41
basically.
some how i can see you laughing your a$$ off and having coffee spill out your nose as you fall to the ground
#42
#43
i thought about using scotch tape and popsicle sticks to seal the unit but thought it would be to expensive so i went this route. hey maybe that diet coke can your using i could use it some how..... hmmm...
#44
drive shaft questions about dual transfercase set-up
i have an 86' 4runner (w/ 2-3in lift) i recently did a solid axle conversion on my truck and while i had it taken appart i decided to add a transfer case, i am almost done with both projects but i still need to have my drive shafts modified. i have found a reputible and realible place to have my shafts modified, but friend with off-road mechanical experance tells me that i will need to add a dubble cardon joint to the rear shaft since it will be at a slightly steeper angle and not as long. i am on a budget and i beleve that the least expensive way to get that joint would be to find one from an 85 toyota, but if i don't need it then i probabily don't want it.
Do i need to add U joint/s to my drive shafts when i modify them?
Does the rear shaft need a dubble cardon joint when shortened for the purpose of a dual transfercase?
thank you for any help
#46
i searched and found very mixed findings and did not find anything that gave evidence to support their claims
could anyone give me a helpfull responce
thank you for the awesome feed back that was soooooooo helpfull, sebastian hommie
#47
however this basically makes your driveline into 2 shafts.
i posted a link to this earlier but here it is again
https://www.yotatech.com/forums/f152/front-driveshaft-pinion-angle-182128/#post51155336
Cheers
#50
so not much happened today, managed to pull the case apart and pull the interlock pin to allow for independent shift rail operation. Also got the adapter on so everything is ready to go in besides the shifter assembly
#51
This is the begining of the milling process but i got alot further than this but i dont have any other pics. i need to finish some small details on the rear shifter assembly but other than that, that part is done.
Now the other project is to figure out the shift lever and all that stuff....
#55
ok i know this might be a dumb question but can somebody explain to me the difference between having dual sticks and triple sticks. like what the fuction of each stick is. i am new to toyotas and am building an 85 xtra cab on 40in iroks and am fixing to put dual cases in it. i am just trying to figure out which way to go being that i still have the bench seat in it.
thanks!
thanks!
#56
thanks!
thanks!
1: H-N-L front case
2: H-N-L rear case
3: 2WD-4WD
For dual sticks, depends on the setup:
w/ 1 case:
1: H-N-L
2: 2WD-4WD
w/ 2 cases:
1: H-L front case (can be 2WD H-L or 4WD H-L depending on rear case)
2: 2H-4H-N-4L rear case
#57
4Crawler - thanks for the info! thats exactly what i was looking for. that being said i do have one more question....would having twin sticks allow me to not have to cut a hole for the rear case or would i have to get a twin stick set up (say from marlin) and either fabricate or order a set up like the one R.DesJardin makes?
again sorry if these questions are somewhat newb...but hey thats what i am.
thanks!
thanks!
#58
Well, think about it. If the shifters come out of the top of both cases, then you need 2 holes for them to pass through. 1 stick or 2 per shifter still need a hole in the floor. Move the shifters to the front case, then one hole is needed.
#59
EAJ,
That is a pretty bitch'n Transfer Case you've got there
lawdawg21,
We've got another discussion on Toyota shift patterns regarding twin sticks that I think you'll find useful:
Read reply #8 and below
https://www.yotatech.com/forums/f116...r-case-231669/
Regards,
BigMike
lawdawg21,
Regards,
BigMike
#60
this is awesome, nice fabrication, and that program...solidworks...i think i read it somewhere...that is awesome too...i think I might get something useful like that...you are doing good work on this looks nice...
