BLING BLING modified TJM
Old Mar 21, 2006 | 05:26 PM
BruceTS's Avatar
After working on a solution to make these things work with the stock wiring, I finally figured it out!
today I welded in the square holes of the TJM-15 bumper turn signals and fitted the sequential LED units, which use a standard oval openning.
Here's a few shots showing one in action
Old Mar 21, 2006 | 05:28 PM
spindleshanks's Avatar
neat!
Old Mar 21, 2006 | 05:29 PM
FilthyRich's Avatar
Very nice.
Now you will get bombarded with how you did it and where the parts came from.
As always, very clean !!!!
Old Mar 21, 2006 | 05:30 PM
garrett1478's Avatar
cool!
did you modify the wings to follow the lines of your fenders? looks really nice.
Old Mar 21, 2006 | 05:47 PM
BruceTS's Avatar
Originally Posted by garrett1478
cool!
Had to do that almost right away, with the wider fenders the bumper looked wierd. Fabricated wings then welded them on, also put a bevel on them as well. Here's the thread about it.
To fill the hole, I purchased a oval light mounting plate, then used it as a template to cut the filler pieces out. After welding them in place, I scribed a line where I needed to cut excess material off. I will be installing 3" fog lights next to them once they arrive, so I made sure to leave room for them.
As for getting them to work....."That Proprietary information" NOT!......lol
I had to replace the factory flasher unit with one that could be easily modified to ignore the burned out bulb circuit. An aftermarket EP35 Triton unit did the trick, cut pin 7 on the IC and everything works perfectly. The rate of the flasher can be adjusted by changing one of the resistors, this made it possible to time the on cycle, long enough to have all 5 arrows sequence. for more info on the flasher go here
Old Mar 21, 2006 | 05:51 PM
Bob_98SR5's Avatar
hey bruce,
pretty trick, i must say good job! looking fwd to seeing your truck at DV
bob
Old Mar 21, 2006 | 06:15 PM
Localmotion's Avatar
how much did it cost you?
Old Mar 21, 2006 | 06:16 PM
lee's Avatar
lee
that looks cool
Old Mar 21, 2006 | 06:22 PM
calrockx's Avatar
bruce told me about this mod a while ago. knew this day was coming, and now here it is. i promised myself i wouldn't cry *tear* haha
neat mod. i'm content with the stock tjm lights, but i guess if i ever destroy/water damage them, these fancy things are something i'd look into..
Old Mar 21, 2006 | 06:40 PM
BruceTS's Avatar
I purchased mine off eBay for $105 but here's where I had planned on getting them from; http://www.vehiclelight.com/9556.html. Then another $8 for the bracket to use as a template...... I bit pricey, but it's about the BLING!
I saw them on a trash truck in my neighborhood, that gave me the original idea. I then did an extensive search on the net, til I finally found them.
Old Mar 21, 2006 | 06:47 PM
d0ubledown's Avatar
now thats trick! bling indeed bruce...you should make that an animated gif haha
Old Mar 21, 2006 | 07:16 PM
calrockx's Avatar
wanted to see if i could do it
Old Mar 21, 2006 | 07:18 PM
you da man calrockx!
Old Mar 21, 2006 | 07:47 PM
BruceTS's Avatar
That's real close to the actual rate even! Nice job Charles...... Yea I know you did it to see how they would look for your rig..... Only took me 2 hours to install........
there's also a 3rd wire that can be attached to the parking lights, I may hook this up as well....
Old Mar 22, 2006 | 12:55 PM
wjwerdna's Avatar
wow, that is awesome
Old Mar 22, 2006 | 05:07 PM
calg3's Avatar
Good job, very nice work
Old Mar 22, 2006 | 06:05 PM
joez's Avatar
VERY nice job, i dig it.
Old Mar 23, 2006 | 03:12 AM
OutdoorLiving's Avatar
Bruce, that is PIMP.
Old Mar 24, 2006 | 10:54 AM
RobT2k's Avatar
I like that he was inspired by the Trashmans ride...
And then did it!!!
Old Mar 24, 2006 | 10:58 AM
BruceTS's Avatar
And then did it!!!
finally someone brings it up............ROFLMAO
Yes, it was even trash day today, they have them mounted on the sides midway on the trucks.........
