Bad Rust !!! Fixable???
Old Dec 6, 2007 | 05:45 PM
yotabob88's Avatar
problem is mine isn't safe to drive! selling as a parts only truck or parting out !!
Old Dec 6, 2007 | 05:51 PM
da_bigg_wigg's Avatar
a quick solution would be to find some old signposts that no one is using and rig up a frame by bolting a few together. there was a thread on that here just recently. looked pretty good... hehehe
Old Dec 6, 2007 | 06:08 PM
isaac338's Avatar
ahhahahaha. da_bigg_wigg, purveyor of terrible advice.
Old Dec 9, 2007 | 04:52 AM
Cumminspwr's Avatar
nice truck that frame is pretty bad but it is fixable im actually doing that right now with my truck my advice is to find a frame or like i did found a backhalf of a yota frame that had been turned into a trailer and im in the process of cutting my frame off and welding this to it, i had a buddy (he drove the truck) that the frame was rusted so bad that the only thing holding the rear leaf spring mounts on was the weight of the truck the mount had rusted all the way through it, but it looks pretty bad so i could look at back halfing it, and on the welder id set it at 120 or a lil lower with a 7014 rod n give that a shot, just i would have a buddy come over n weld the sides becuase stick gets pretty messy if you never used one
Old Dec 9, 2007 | 04:30 PM
  #25
bigarms23's Avatar
start of right and get a replacement frame from cal mini its just the smarter thing to do
Old Dec 9, 2007 | 04:54 PM
  #26
-MUDSLINGER-'s Avatar
Well sence your a student you should take some sort of welding class and section the frame and rebuild, or get a frame from a junk yard, IFS shortbed frames are everywere, maybe you can do it for some kind of project for a automotive class in the off time, or part it out. Good luck!
Old Feb 18, 2008 | 11:14 PM
  #27
dougnchico's Avatar
do you still have this truck
i just fixed the frame like this on a 91 nissan 4x4 with no problem and no worry i would like to buy this truck and put it back together. oh yeah i've been a welder for 23+ years
Old Feb 20, 2008 | 01:59 PM
  #28
94slammedyota's Avatar
get a replacement frame man! thats the best way to go!!! very nice truck to sell as "parts truck" take some time out and make it "your" truck.. replace the frame!!!!
Old Feb 21, 2008 | 09:51 PM
  #29
4Rocker's Avatar
I have successfully welded some patch panels on my 84's frame that has lived in MN all of its life. 1/4" is WAY too thick for welding to a frame like this. The stock frame steel thickness on these trucks is around 1/8" which should be plenty strong.
Old Mar 8, 2009 | 05:31 AM
  #30
diamond d's Avatar
Welder/Fabricator
Originally Posted by yotabob88
Well My dad Got me this truck as a graduation Gift and well I drove it for a while and then the brakes started to grind so I put it on a lift to check them and the frame just gave out!! But I'll Give you guys a link to photo bucket to look at the damage my question is would it be repairable I have an 220v arc welder but I've never arc welded before (Got welder from my grandpa) is it possible? and what type of metal and rod should I use, I will buy extra for practice
Oh I've MIG welded thing gauge steel before for collision repair in highschool.
Photo Bucket:
http://s222.photobucket.com/albums/dd259/bobmartin888/
Well Bob, after seeing those pictures of the rusted frame on your pick-up, as a professional in the field of welding & fabrication, it can be fixed, but it's not a wise thing to do! My advise to you, even though you might not like it, is to get rid of it, & find something with a sound structured frame.
Old Mar 8, 2009 | 06:18 AM
  #31
1stgen4gunner's Avatar
New frame, not necessarily.
It's going to take quite a bit if work though, and you should have a more experienced welder do the welding portion of this.
1. Sand the paint off the portion of the frame with the rot with an electric sander and medium sand paper until you get bear metal (this will help you find the rot under the paint)
2. When you have found all the rot, use a plasma cutter to cut off the bad portion of the frame
3. Find steel plating a 1/8" thick (don't forget to use your tape measure to measure how much you need), or cut off another section of another frame, maybe a parts truck?
4. Have an experienced welder with an Arc Welder weld in the section of the frame, (you may want to put steel plates over the weld just to help re-enforce it)
5. Let it cool!
PS. Just my opinion but I think you should sand the entire frame and prime it then spray it with 3 coats of rust preventative paint when you are done.
.....just my 2 cents
Old Mar 8, 2009 | 07:54 AM
  #32
bigt's Avatar
well this post is from 07 so i assume he has dealt with this haha
Old Mar 8, 2009 | 09:55 AM
  #33
Oh crap are you serious, I just spent a good 15 minutes of my life trying to help the poor fellow....owell
icentropy
Sep 16, 2020 02:47 PM
cars-guy
Aug 16, 2020 06:59 AM
young buck
18
Aug 27, 2018 02:40 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
