82 frame repair
Old Jan 29, 2015 | 10:30 PM
Alvin907's Avatar
82 frame repair
Picked up a cheap 82 and it's got a lot of frame rust. So after work I have been cutting out sections of rust to solid metal and replacing it with 1/8 steel. Then my plan it's to fish plate it.
Old Jan 29, 2015 | 10:56 PM
Alvin907's Avatar
Old Jan 30, 2015 | 04:25 AM
Terrys87's Avatar
You are doing a great job on getting that frame back into shape. Glad to see you getting another one back on the road. Welcome to Yotatech.
Old Jan 30, 2015 | 08:06 AM
Alvin907's Avatar
Thanks a lot! I wanted a solid axle and it was a good price, everyone in Alaska wants an arm and both legs for yotas. Floor is rotten and PO did an amazing job of acting like they new wht they were doing so it should be fun trying to figure out there work while learning about this old thing myself hahah
Old Jan 30, 2015 | 03:40 PM
Alvin907's Avatar
I need to come up with leaf spring hanger brackets if anyone has any ideas that would be awesome!
Old Jan 30, 2015 | 05:49 PM
dropzone's Avatar
Fossilized
http://www.lowrangeoffroad.com/yotam...d-hangers.html
Old Jan 30, 2015 | 11:49 PM
Alvin907's Avatar
Let the fish plates begin
Old Jan 31, 2015 | 03:11 AM
Terrys87's Avatar
I meant to ask earlier, but what is fish plates? or what do they actually do?
Old Jan 31, 2015 | 03:21 AM
dropzone's Avatar
Fossilized
they bridge between splices..if that makes sense
quick pic from google
Old Jan 31, 2015 | 03:24 AM
Terrys87's Avatar
Thanks dropzone. I appreciate it. I have seen them before and just never put the two together.
Old Jan 31, 2015 | 10:42 AM
Alvin907's Avatar
Thanks dropzone. After I bought this truck and looked at it in daylight, I was contiplating using the axel for a SAS on my 95 but now I am super stoked on this 82 rebuild.
Old Feb 1, 2015 | 06:43 PM
Alvin907's Avatar
Almost done with one side of the frame! Man it's hard to get it done with limited time and duty cycle,
Old Feb 1, 2015 | 10:21 PM
morena67's Avatar
subscribed... °°° !!!
Old Feb 2, 2015 | 02:12 AM
wyoming9's Avatar
Red face
There is no reason that needs to be welded solid other then you getting carried away. Happens all the time!!
With the Plug welds A few stitch welds every few inches is more then enough for structural strength.
Quite easy to make your own spring hangers
Just goes to show any frame can be repaired if one wants to spend the time.
Old Feb 3, 2015 | 07:05 AM
Alvin907's Avatar
Finished the inside rail now hanger brackets and bust out the other side
Old Feb 7, 2015 | 10:45 PM
Alvin907's Avatar
Started on the other side today.
Old Mar 23, 2015 | 07:33 AM
88xtra4x4's Avatar
Wow! Amazing job with that frame repair!
Old Mar 25, 2015 | 03:14 PM
Alvin907's Avatar
Thanks a lot!! Waiting for leafsprings hanger brackets now , then on to the cab haha
Old Mar 31, 2015 | 09:00 PM
Alvin907's Avatar
So I built some brackets and the previous owner had hacked/moved the old one out of place. So I have measured from front to rear rims, cross measured axel to frame and it all seems square but one of the shackles is setting back at more of an angle. I was wondering what your take on that would be.
Thanks a lot
Old Apr 8, 2015 | 09:30 AM
superex87's Avatar
measure the spring eye and compare it with the other spring. If the problem spring is flatter then its partner then the shackle angle will be different.
