3/16 or 1/4 steel for rear bumper?
Hey,
I'm looking at a custom bumper, the guy will make it out of 3/16 or 1/4" steel square tube, which should i go with? it has a recever hitch with no supports from the frame mounts into the center to support the hitch, only the brackets streight out from the frame, will it bend outword in the middle if i tow from it? Thanks -Jeff
Yeah the guy has an awesome design, I've been searching around and see that 3/16 and 1/4 are both common. I like strength but theres also arguments that if you go to strong you screw up the frame if you take a hit and it's that much more weight too. Thanks for the response, I am leaning towards the 1/4". Thanks again.
i would not be worried about the tube the bumper is made of i would be worried about those frame brackets, even if they are 1/4" any decent side load will bend flat plate, i would consider welding that lower bolted section and then adding some cross bracing from theend of the frame to the center to laterally support those brackets.
that would be my worry, i had a doulbe tube bumper made in the 80's that had 3/8" steel brackets like those and a honda civic backed into it and moved it 3" over at less than 5 MPH!!!
that would be my worry, i had a doulbe tube bumper made in the 80's that had 3/8" steel brackets like those and a honda civic backed into it and moved it 3" over at less than 5 miles per hour!!!
3/16" for the main tube is probably more than enough for anything a toyota can tow, i would make sue the angle brackets are still at least 1/4 though
Jun 1, 2021 01:51 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
