3/16 or 1/4 steel for rear bumper?
Old Jan 21, 2010 | 09:09 AM
yotaluver's Avatar
Hey,
I'm looking at a custom bumper, the guy will make it out of 3/16 or 1/4" steel square tube, which should i go with? it has a recever hitch with no supports from the frame mounts into the center to support the hitch, only the brackets streight out from the frame, will it bend outword in the middle if i tow from it? Thanks -Jeff
Old Jan 21, 2010 | 09:11 AM
camo31_10.50's Avatar
search around a bit to get some ideas on designs
and use 1/4 for strength
Old Jan 21, 2010 | 09:22 AM
yotaluver's Avatar
Yeah the guy has an awesome design, I've been searching around and see that 3/16 and 1/4 are both common. I like strength but theres also arguments that if you go to strong you screw up the frame if you take a hit and it's that much more weight too. Thanks for the response, I am leaning towards the 1/4". Thanks again.
Old Jan 21, 2010 | 09:30 AM
mr ugly's Avatar
1/4 for where the reciever will tie in back to the frame. 3/16 for the rest.
Old Jan 21, 2010 | 09:37 AM
swapped89's Avatar
X's 2
Old Jan 21, 2010 | 09:42 AM
yotaluver's Avatar
theres a pic of it, so the whole thing is gonna have to be the same...
Old Jan 21, 2010 | 10:33 AM
ryantowry_81's Avatar
i would not be worried about the tube the bumper is made of i would be worried about those frame brackets, even if they are 1/4" any decent side load will bend flat plate, i would consider welding that lower bolted section and then adding some cross bracing from theend of the frame to the center to laterally support those brackets.
that would be my worry, i had a doulbe tube bumper made in the 80's that had 3/8" steel brackets like those and a honda civic backed into it and moved it 3" over at less than 5 MPH!!!
Old Jan 21, 2010 | 10:52 AM
kenbo53's Avatar
i agree def want something to stiffen the mounts side to side. i would think 3/16 would have plenty of strength with that big of a piece of tubing plus if it were 1/4 ited be ridiculously heavy
Old Jan 21, 2010 | 11:42 AM
yotaluver's Avatar
that would be my worry, i had a doulbe tube bumper made in the 80's that had 3/8" steel brackets like those and a honda civic backed into it and moved it 3" over at less than 5 miles per hour!!!
Looks like it's angle iron up to where it bolts to the frame, think thats good enough or need more support? so ur thinking 3/16 is fine to tow off then?
Old Jan 21, 2010 | 12:13 PM
Etype R's Avatar
Without having bracing from the receiver tube angled out to the frames, I wouldn't tow anything to heavy. For a light trailer it should be ok. I wouldn't pull a larger boat or car trailer with it though.
Old Jan 21, 2010 | 12:34 PM
3/16" for the main tube is probably more than enough for anything a toyota can tow, i would make sue the angle brackets are still at least 1/4 though
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
nick9455649
Sep 11, 2015 05:10 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
