THE 1 MILLIONTH SAS (on my 92 runner)
Old Jan 24, 2006 | 08:40 AM
  #101
joebruva25's Avatar
The problem is that this is on a 92' 4-runner and it is a coil spring setup so I don't have a stock hanger to measure from (which every body has written that you measure 8-1/2"-9" from stock location if you have a leaf spring setup already) so I guess I could go 3-1/2"(7"/2=3-1/2") farther forward than your measurement cause my springs are 7" longer than yours, the reason i'm asking all these questions is cause i want to measure 4 times and weld once so i don't dog walk like you are talking about and end up having to cut off the hangers.Thanks again for the reply
Old Jan 24, 2006 | 10:16 AM
  #102
4rnr's Avatar
Oh I thought you were doing to the truck in your avatar. I would position the axle where you want it and tack up one hanger. Then measure the distance from the front of the rear hanger to the front of the front hanger and use that measurement to locate the other rear hanger, that way not only will they be he same but it will be square witht the front hanger, and your truck should then be square.
Old Jan 24, 2006 | 02:29 PM
  #103
4rnr's Avatar
Iam bassically waiting on parts, calipers, union tee, 3rd members, d-shafts, etc.. I also ordered a set of 36x12.5r15 tsl sx's, today
Ive been talking to dave at marlin about the kit and he is sending me some parts to play with for a rear bumpstop system and an upper shock mount set up for the 2nd gen runners, since their kit doesnt have one. So basically now im a R&D vehicle for Marlin Im going to do some work to the parts that I get and put it all togeather and see how it works. Ill keep you guys and marlin posted on how that all goes. and maybe youll see my idea on the sas kit
Also I started cutting body away in the quarter panels because my axle was a little to far back even after I moved it up a hole on the perch. Plus Im going to be running the 36's and Im going to be setting up the rear bump stops so I can tuck way up under the body. I think Im going to go with High angle driveline for the d-shafts bc its not expensive and they know what they are doing on a toyota. But they said that I will not be able to drive above 5mph without the front shaft vibrating!?! I heard guys could pull it off on auto v6's with a single case.
Old Jan 24, 2006 | 06:33 PM
  #104
Napoleon047's Avatar
sounds like they are just covering their ass, maybe. are you running a HP front third?
i have a single t-case and low pinion front. i can hit 45 w/o vibes with my square front d-shaft
Old Jan 24, 2006 | 07:22 PM
  #105
4rnr's Avatar
Thats what i thought, they may be covering their ass. Jessie seems to now a lot, which I know the owner of high angle DL would, escpecially about toyotas, and their prices are cheaper than buying the spline kits and having them made by joe schmo here in the anti offroad capital of the country, chicago.
Are you running a manual?
Hey who knows how many grams of shot/ball bearing/bb's I need to put in a 72lb 36" tsl.
Old Jan 25, 2006 | 10:42 AM
  #106
4rnr's Avatar
WOW I got totally screwed by the guy with my 3rd, he had it for 3 mo. and dint do anything but take it apart. and I had to threaten him with the cops to get him to even let me COME TO PICK IT UP AT HIS CONVIENIECE!!!!
So basically now I need these 3rds set up and all the BS shops in chicago want $400/diff for setup!!, does anyone know of someone around here or does anyone who what they are doing want to do it, I just dont have the tools or time.
Old Jan 25, 2006 | 04:52 PM
  #107
yotaman's Avatar
Talking
Mail your 3rds to a professioanl "ZUK " (gearinstalls.com). He does nothing but Toyota 3rds. He knows how to make them strong as hell.
I just shipped him both of my e-locking 3rds today for him to install cryo'd 5.29's. He charges $200.00 to intall gears. It cost me $76.00 to ship both of them FedEx ground.
Tell him Greg Bennett set you.
Old Jan 26, 2006 | 11:44 AM
  #108
4rnr's Avatar
I gave him a ring he says hi to you. Great guy seems to know his ˟˟˟˟˟. It looks like our 3rds will meet and share some bench time. Just tell your cryoed, trd e-locked, v6 3rds not to pick on my little 20 yr old 4cyl, non cryoed, lunch box locked, 3rds
Old Jan 26, 2006 | 01:11 PM
  #109
AznSky's Avatar
also if you want another place to work with, try www.jcroffroad.com They're located in Kalamazoo, MI which is about a 3 hr drive from Chicago I'd say.
I got my gears setup by them, their friends of mine and ex-club members.
Old Jan 26, 2006 | 10:24 PM
  #110
yotaman's Avatar
Talking
Yea he’s a great guy. He’s really been good about answering questions I've had.
I’ll be sure to tell my 3rds to not pick on yours to much .
Old Jan 27, 2006 | 06:29 PM
  #111
4rnr's Avatar
Ok update, im basically done but im now just waiting for parts, I mailed out my 3rds to ZUK in az. I ordered driveshafts from jessie at high angle drivline (great guy) waiting for 2 calipers, 36" tsl sx's, and the parts from marlin to try and make the bumpstops and upper shock mounts for the rear end.
Im getting antsy, I spent every night from 5pm-2am in the garage for 3 weeks. Now Ive got nothing to do. I think I might push the thing out of the garage and reorganize the garage, if I do that then Ill flex her out and get some poser pics for ya'll.
Old Jan 28, 2006 | 09:27 AM
  #112
4rnr's Avatar
DAAAMMMMNNNN I cant move the truck with out a rear 3rd!?!?! It looks like it could wreck the seals, bc the 3rd holds the shafts in place. IM PISSED.
Old Jan 31, 2006 | 10:05 PM
  #113
yotaman's Avatar
If you can, post a picture of what you did with the panhard braket mount. Did you cut it off and plate it or just cut it off?
Old Feb 1, 2006 | 04:51 AM
  #114
PAhydrohead's Avatar
Im getting antsy, I spent every night from 5pm-2am in the garage for 3 weeks. Now Ive got nothing to do...
Ahhhh the good old days, working on the truck whenever you want. Get married and have some kids, then you'll have something to do!
Old Feb 1, 2006 | 06:07 AM
  #115
4rnr's Avatar
My fiance helps when shes not working on her fj62. If I ever stoped wheeling or wrenching, she would call me a ˟˟˟˟˟
As for the panhard I just hacked it off w/ the plasma and left it.
Old Feb 1, 2006 | 07:27 PM
  #116
4rnr's Avatar
I decided to mount my shocks like this, im not sure why some people mount like this.. / \.....
Heres a teaser on all 4's, its all I have that looks decient,
Oh btw the springs havent even begun to droop, in fact the shackles still have about a -30* angle on them, I figure it should droop WAAAAAAAAY more...
Old Feb 2, 2006 | 06:03 AM
  #117
Blizzard's Avatar
Your truck and work are nice! I want a SAS or I want to win the lottery or better both...
Can't wait to see it with the new tires and completed
David
Old Feb 2, 2006 | 09:11 AM
  #118
Hey 4rnr, did you wax your truck for that photo op?? She looks mighty shiny. Is that an engine hoist I see flexing the front end?
Old Feb 2, 2006 | 02:13 PM
  #119
rockota's Avatar
So that the shock eyes are perpendicular to the axle - this allows articulation w/o binding the shock eye. They way you have them mounted, there may be binding. Likely not a big deal...
Old Feb 3, 2006 | 08:21 AM
  #120
4rnr's Avatar
I check to see if the way I have it will bind and the bushings have enough flex in them that I can put about a 30* angle on them using little more force than the wieght of the shock, so I should be ok. Plus in order to mount the shocks like this / \ they would have cris-crossed ( X ) bc the shock is long and the truck is sitting pretty low, as you can see from the shackle angle. I did some research and found that alot of guys started like this / \ and switched to this l l bc of stability, abd after thinking about it it makes perfect sence bc the truck is able to pivot or teeter on the narrow couple inch base provided by the upper shock mounts when they are like this / \, but its all hypathetical and I will see how it does, I could be wrong.
No I didnt wax it but it does look strangly clean now that you mention it, escpecially since it is COVERED in metal dust from all of the grinding and cutting.
