Arizona Arizona Chapter
I need some help, 4runners hurt.
Old Feb 18, 2008 | 11:15 AM
SOAZtim's Avatar
Thumbs up I need some help, 4runners hurt.
I think I need a third member quick.
There is a lot of friction in the rear end. It sounds and feels (vibration is shakes the whole car) like it is in the rear diff.
At just a couple miles an hour its harsh enough to halt the car and make a squeeking noise.
It would come on every couple of feet. About every revoltion of the tires.
The car will roll fine at idle speed in drive for a couple feet and then the rear end will bind up and bring it to a halt. I can overcome it by applying a little gas, but it doesn't feel good!
I rolled back and forth, in high 2wd, 4wd, low 4wd, center diff locked and unlocked and it does it in every scenario.
The weird part: after a bit I gave it some gas, okay a but much, and it stopped. Completely. No more grinding, no more noise, or vibration. No leaks even at the time.
Now today a leak has developed where the pumpkin bolts together.
All in all, its obviously not good. I need a new third member. Preferably elocked while I'm replacing it, but I'll take anything. This is my daily driver and I need to get to work.
Old Feb 18, 2008 | 11:52 AM
Elvota's Avatar
Sorry to hear this problem is still occurring.
I assume you are in Phoenix... or are you hung up in Tucson still?
Is there anyway it's anything to do with your brakes?
What about this idea. Pull your rear DS completely. Engage 4WD and see if things are still binding . Might give you another clue as to the source with zero engine load on the rear axle.
Just brainstorming.
Old Feb 18, 2008 | 11:54 AM
Elvota's Avatar
By the way... I have a V6 3rd from my '90 with 4.56 gears sitting in my garage. If it will fit, and work for you... you are welcome to borrow it for a while.
Old Feb 18, 2008 | 01:24 PM
westy44runner's Avatar
Tim - check your PM's...and if you dont get over to TTORA soon check into this -
http://phoenix.craigslist.org/pts/532803138.html
Non-elocked 3rd gen 4runners have the regular Toy V6 8" diff.
Old Feb 18, 2008 | 02:28 PM
SOAZtim's Avatar
I made it back from Tucson somehow. Did about 45 and I'd stop to check the rear diff a lot. It was hotter than I've felt it, but I just tightened a couple of the bolts and kept going...
Thanks westy. LM for him. "sonoran fabrication" was the number on the add.
Hmm. Is it Steve S evil twin...
Elvota, seems to just be in the axle. I got under there and turned the wheels with the axle off the ground. Its very quite now. Almost like I sheered teeth before and now it is just clunking waiting to fail... ?
Old Feb 18, 2008 | 02:57 PM
Elvota's Avatar
Well... it looks like my 4.56 V6 diff I have would work on your 4Runner if the E-locker on CL falls through.
Let me know and I can bring it over so you don't have to put any more miles on your time bomb.
Old Feb 18, 2008 | 03:01 PM
SOAZtim's Avatar
Just brainstorming.
Really! I wasn't totally sure it would. I guess as long as I was in 2wd it would work.
I'll do some searching/calling today and tonight to see what I can come up with and that may be the way to go.
Old Feb 18, 2008 | 03:33 PM
wormhole's Avatar
Tim, check your mailbox.
I wonder though if this had something to do with it?
Old Feb 18, 2008 | 03:34 PM
Elvota's Avatar
Most likely the ratio won't do for 4WD, but in 2WD things should be fine. Do you have any idea what ratio your truck has now?
Actually... I wonder with auto hubs and the front diff is spinning all the time that a different rear ratio in the rear would cause problems?
If we can't be sure, we could pull the front DS to be safe. That would eliminate the possibility of the transfer case being "fed" 2 different ratios from the front and rear axles.
Maybe someone will chime in.
Old Feb 18, 2008 | 06:23 PM
Zona4r's Avatar
Tim,
are you running an extended rear diff breather? Maybe sucked some river muck in somehow with that crossing.
You should be running 4.10s. E-locked is 4.30s
Old Feb 18, 2008 | 07:12 PM
SOAZtim's Avatar
T, I'm not responding to you. That photo is photoshoped. I would never do that! haha! Just kidding.
Zona,
I do have an extended breather. I still may have sucked some in though.
It has 4.10's by the vin # chart I've looked up before.
Old Feb 18, 2008 | 07:16 PM
wormhole's Avatar
Old Feb 24, 2008 | 06:35 PM
toy_tek's Avatar
Tim sorry to hear about this. What is the latest? Let me know if you need anything.
Here is some good toy diff info. Will let you know what will fit and what won't:
http://home.4x4wire.com/erik/diffs/
Old Feb 24, 2008 | 07:24 PM
SOAZtim's Avatar
I've got some parts ordered. There will be a few fun nights taking the front and rear diff out.
I really want to get it up and running again soon...
Old Feb 27, 2008 | 09:43 PM
SOAZtim's Avatar
Thanks to 111db for the extreme help, storage etc etc!!
Snagletooth.....
oops
mmm chunky
Old Feb 28, 2008 | 03:28 AM
wormhole's Avatar
Dang, that might be a problem.
How was pulling the front and rear diff?
Old Feb 28, 2008 | 06:07 AM
SOAZtim's Avatar
Oh I don't know. A little JB weld and som puddy?
Hello gears.
Old Feb 28, 2008 | 06:58 AM
toy_tek's Avatar
I think we did pretty good: he pulled in the garage at 6pm and we had them both out by 8:15 or so.
Old Feb 28, 2008 | 07:02 AM
Elvota's Avatar
"Pretty Good"? 2:15 for a dual diff pull has to be close to NASCAR standards.
Some good damage their Tim. No wonder you had some noise issues. You are going to really enjoy that locker... but I am sure I don't have to tell you that.
Old Feb 28, 2008 | 08:15 AM
SOAZtim's Avatar
Thanks Elvota. I can't wait! Jon was doing all of the hard work. I felt like a supervisor. Mmmkay. Yah thats good. yah. mkay.
Thanks again Jon. You still have to tell me what kind of beer and your fridge will be full... Unless you have a HUGE fridge in which case a case will be over in the corner of it...
