What are these built axles worth
Old Nov 28, 2008 | 08:13 PM
cstamm's Avatar
I happened across these: What do you think is a fair price for them? Will they pretty much be bolt in on my 88 V6 pickup with SAS? It's running the stock rear axle and an 84 solid axle in the front. I wanted to regear and install lockers anyway, this could save me the hassle.
The ad:
BUILT TOYOTA AXLES
-FRONT- 1985 MODEL FULL TRUSS
5.26 YUKON GEARS
VENTED ROTOR COVERSION NEW
BIG BORE CALIPERS NEW
PADS NEW
DETROIT LOCKER
WARN HUBS
CUSTOM HIGH STEER COVERSION PROFESSIONALLY BUILT
9/16 WHEEL STUDS
-REAR- 1987 IFS WIDE REAR AXLE
5.29 YUKON GEARS
VENTED REAR DISC CONVERSION
NEW CALIPERS
GOOD PADS
FULL SPOOL
9/16 WHEEL STUDS
EVERYTHING ON THESE AXLES WERE DONE AT A MAJOR OFFROAD SHOP IN NORTH CAROLINA ANY QUESTIONS CALL.
Old Nov 29, 2008 | 07:01 AM
tc's Avatar
tc
Do they have Longfields in the front and did they do a full-float conversion in the rear to get the discs?
Old Nov 29, 2008 | 07:06 AM
akaphilly's Avatar
nice axles, i'd say 2000 ish depending if thats a full detriot and not just an ezlocker
Old Nov 29, 2008 | 07:10 AM
cstamm's Avatar
not sure on the details, I have to call the guy. I think the rear spool would have to go though. $2000 ish, wow, He is practically giving them away then IMO. I'm just a little gun shy because it's real hard to know if everything was set up properly.
Old Nov 29, 2008 | 07:14 AM
cstamm's Avatar
Will they pretty much be bolt in on my 88 V6 pickup with SAS? It's running the stock rear axle and an 84 solid axle in the front. Is an 87 IFS wide rear axle (as per his description) the same as my 88 stock V6 axle?
Old Nov 29, 2008 | 07:35 AM
akaphilly's Avatar
yea dude it will work. then u can sell your old axles for a couple hundred, not sure about thoes 9/16th wheel studs? he didnt list spacers for the front axle so you might need thoes to match the rear
Old Nov 29, 2008 | 07:45 AM
cstamm's Avatar
ya I'm not sure what he means by the studs either. I have the front wheel spacers on now, but thanks for the heads up. I've been out of the older Yota stuff game for awhile, so I want to make sure I don't make a bad decision here and overlook something. He only wants 800 for them both, which seems hard to pass up.
Old Nov 29, 2008 | 07:51 AM
ScottyC's Avatar
I've seen similar setups go in the $1100-1300 range. That is with highsteer from Marlin, All-Pro, or Trail-Gear. If it is some welded together hack job, then walk away. Warn hubs suck, so swap over your Aisin hubs from your current axle.
What is the guy asking for them?
It may be worth it to just swap the 3rds into yours already. Your V6 rear 3rd will be stronger, but if the setup was spot on, a 4cyl is only marginally weaker. You will lose your E-brake with the rear discs though. And, there isn't much of a remedy for that since you have a V6.
Old Nov 29, 2008 | 07:54 AM
BLKNBLU's Avatar
Personally I think I would HATE spool rear and full time front locker. Yuck. Especially back there in PA where you get weather. Maybe swap the Detroit diff to the rear and get an ARB installed into the spooled 3rd and put that up front.
Also they could be 4 cyl diffs which some argue are less strong than 6 cyl, but I personally think it's not enough difference to worry about especially if the deal is good enough.
Old Nov 29, 2008 | 07:59 AM
BLKNBLU's Avatar
Also here is a write up about 9/16th studs. It's considered an upgrade by many. Others think the ARP studs are just as good.
http://www.pirate4x4.com/forum/showthread.php?t=394089
Old Nov 29, 2008 | 08:23 AM
ScottyC's Avatar
That is not the same as what is on these axles. He is referring to wheel studs, not steering studs.
Old Nov 29, 2008 | 08:27 AM
cstamm's Avatar
He only wants $800 for both. I got all excited at first, now I'm realizing they might not be the way to go for me. Too many things I don't want, rear discs, rear spool, 4 cyl diffs. Still seems like a screaming deal to me though.
Old Nov 29, 2008 | 08:44 AM
BLKNBLU's Avatar
Thanks. I wasn't paying attention.
Old Nov 29, 2008 | 09:12 AM
[N8]'s Avatar
Saw those same axles on CL & decided they were not worth it :|
Old Nov 29, 2008 | 09:17 AM
ScottyC's Avatar
I would buy them and sell them off then. The front 3rd is worth $500 alone IMO. Use that by itself, and then sell off everything else to afford to regear the rear with whatever locker you want.
Highsteer would net $199 for a used setup.
front axle by itself is $300 with the vented rotors and IFS calipers.
The rear is another $500 with the 5.29 3rd and spool.
The rear disc conversion is around a $400 mod alone, so you might get more for the rear axle too.
Old Nov 29, 2008 | 09:26 AM
[N8]'s Avatar
Good points ScottyC & I think I should rephrase (not that it matters, hehe):
They weren't what I was looking for and I don't want the hassle of buying them & reselling them myself. I'm sure they're a great deal to anyone looking for a setup similar to that.
Old Nov 30, 2008 | 12:15 PM
cstamm's Avatar
I got this response back from the seller
the front axles are still birfields the gears have been broke in properly the rear axle is not a full floater it has sky manufacturing caliper mounts and chevy yukon rotors the gears where installed on my 4-runner in NC when i worked at a shop called Extreme Offroad there is a my space page for the shop we did everything there from full tube chassis for rock crawling and circle track racing and daily driven trucks on 49 iroks so everything is done right on these axles
Anyone ever heard of Extreme Offroad in NC? I know there are a lot of hack off road shops out there. ScottyC's recommendation to buy them and part them out might not be a bad idea.
pplusent
Sep 18, 2018 10:02 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
o2raybid
Sep 4, 2015 12:45 PM
priest16
15
Aug 6, 2015 07:43 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
