What size spacer to level?
Old Jun 21, 2005 | 05:37 PM
chas4runner's Avatar
http://markheffron.netfirms.com/4runner.html
Hey guys,
I installed OME890 Springs-Rear and OME-880 Springs-Front on my 1996 4runner. The front is sitting a good 2" lower than the rear. What size spacers would you recommend to bring it level. Any other ideas?
Thanks
Old Jun 21, 2005 | 05:48 PM
well since the front is sitting 2 inches lower than the back.....you should probably get a 2 inch spacer. i have cornfed's 2 inch spacer up front on my runner and havent had any problems with it. www.cornfedsuspension.com hope that helps.
Old Jun 21, 2005 | 05:49 PM
94x4's Avatar
Guest
I would be happy if mine sat like that, makes it possible to carry necessities without being noticable.
Further, I think that it was designed to sit that way for that purpose.
Old Jun 21, 2005 | 05:55 PM
It doesn't look that bad in that picture....A bit more like a "dragster" on a flat surface
Old Jun 21, 2005 | 06:00 PM
Mickdady's Avatar
I think 2" would be too much. I put on 2 sets of spacers that Andy makes and got 1.5" of lift. From stock this gives exactly 3". Anymore than that and you will run into issues with CV angle and control arm contact. Mine sits almost exactly level.
I will post pics as soon as I can get my camera charged.
Old Jun 21, 2005 | 06:07 PM
Mick,
Did you do the spacer install yourself?
Old Jun 21, 2005 | 07:54 PM
Mickdady's Avatar
yup, took about an hour. I have done several runner lifts so I am pretty familiar with the suspension. I could work up a write up if you are considering going this route. Andy might have one too. Its pretty easy...the hardest part is compressing the coils to put the new studs in.
Old Jun 22, 2005 | 05:50 AM
Mickdady's Avatar
Here is my leveled 4runner
I don't really have a before picture because the only one I have is in my sloped driveway and this makes it look level.
AFTER
SPACER
87runner_
Sep 9, 2015 09:51 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
gp66
Sep 7, 2015 08:29 AM
viesail
Sep 5, 2015 04:23 AM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
