Warn winch questions
Old May 25, 2008 | 01:35 PM
High Water Drifter's Avatar
found a good deal on a used warn 9000 premium series. my question is does the clutch handle/ right side of winch able to rotate? This winch i'm looking at has the clutch handle facing front wards, so that it is in the same position as mounting hardware. He had a bumper that had a hole in the front for the clutch handle. Can i loosen hex screws and rotate handle/winch end upwards for my TJM 17?
Old May 25, 2008 | 02:34 PM
Nevermind, looks like i found my answer...thanks for looking.
Old May 25, 2008 | 04:20 PM
Elvota's Avatar
Don't keep the answer secret... post up so others that find this thread in the future can share the wealth.
Old May 25, 2008 | 06:06 PM
crolison's Avatar
ditto
Old May 25, 2008 | 06:39 PM
4rnr's Avatar
Unless Ive understood something he wants to move the handle from its current location buy rotating that assembly of the winch (the planetarys are on that side IIRC) and the housing can be rotated and the bolt pattern works at all 360* positions. rotating the housind/planetarys/handle forward or backward...
Unless I missed something...
Old May 25, 2008 | 07:04 PM
Elvota's Avatar
You only missed his answer ...
... but I am guessing you are on the right track.
Old May 25, 2008 | 07:36 PM
4rnr's Avatar
I was guessing his answer to try and help some of the people inquiring incase he never came and posted up.
oh and....
Old May 26, 2008 | 04:56 AM
dirtoyboy's Avatar
Yes you can clock the clutch levers on 9000s
BeMiceElf
Oct 10, 2015 09:40 PM
priest16
15
Aug 6, 2015 07:43 AM
kvanzandt1
Jul 18, 2015 10:15 AM
Odin
Jul 15, 2015 09:28 PM
