Valvoline maxlife?
Old Sep 22, 2005 | 09:32 PM
BAZ's Avatar
BAZ
Valvoline maxlife?
Has anyone got any feedback on this oil? I need to do an oil change this weekend and have heard from friends that this has worked well for them. I am kind of skeptical using a synthetic oil in my truck because I have no idea what the previous owner used. (conventional/synthetic weight etc.) The truck is a '94 22RE w/110k miles on it.
-TIA
Old Sep 22, 2005 | 09:48 PM
bob200587's Avatar
i use it.....no problems, helps slow leaks for me alot.
Old Sep 22, 2005 | 09:53 PM
msw0085's Avatar
Is there a legitimate reason why you shouldnt use syn after regular? Its highly possible im just ignorant about this, but I havent heard that before and def have changed back and forth in other vehicles.
Old Sep 22, 2005 | 10:06 PM
bob200587's Avatar
no idea, all i know is the syn leaks through places the regular might not. and also I've heard that most wear on an engine occurs during the first 2500 miles....or somethin like that.
Old Sep 22, 2005 | 10:13 PM
BAZ's Avatar
BAZ
I have also heard this (synthetic leaking on high mileage gaskets) and thats exactly why I am skeptic of this oil. This is a full synthetic.
Old Sep 22, 2005 | 10:18 PM
bob200587's Avatar
dont use maxlife synthetic, just regular maxlife.
Old Sep 22, 2005 | 10:24 PM
BAZ's Avatar
BAZ
Wasnt aware they had a non-synthetic version. Its funny, when I went on the Valvoline website they have a section where they tell you what oil is right for your vehicle and they told me I should be running maxlife synthetic.
Old Sep 23, 2005 | 03:48 AM
Dr.Feelgood's Avatar
Bob is right, use the regular Maxlife. My old Mazda started smoking like a SOB (worn rings) and I changed the oil with the Maxlife and 90% of cleared up.
Old Sep 23, 2005 | 05:14 AM
bob200587's Avatar
thats proabably because its $4+ a quart, of course they would encourage it.....so would I to be honest. When I get around to rebuilding my engine, I might make the switch to snythetic.....I might even go back to non-maxlife for a while.....i don't know what goes into consideration about somethin like that.
Old Sep 23, 2005 | 06:25 AM
DH6twinotter's Avatar
I've been using Maxlife (non-synthetic) for a while now. No problems at all. 4Runner has 191,xxx miles on it, and runs great. Does have a few oil leaks, but that has been there since before I switch oils.
Old Sep 23, 2005 | 07:24 AM
getitdone's Avatar
I am using regular maxlife right now. It's good stuff.
Old Sep 23, 2005 | 07:26 AM
Rivalred's Avatar
I am not too much of a fan of Valvoline, but Maxlife might be different. When I use to do my oil changes I loved my Castrol GTX.
Old Sep 23, 2005 | 07:37 AM
bob200587's Avatar
Valvoline and Castrol is equivalent to Ford vs. Chevy........mostly comes from family tradition, and or personal preference. I'm sure that we could do a study on which one does better....but im not up for doing an experiment.
Old Sep 23, 2005 | 08:42 AM
LittleRedToyota's Avatar
in that case, i wouldn't use either.
Old Sep 23, 2005 | 10:01 PM
BAZ's Avatar
BAZ
Well its decided then. Conventional maxlife for me
Now I just have to figure out what weight to run. I have a noticeable valvetrain chatter and have heard that heavier oils reduce the noise significantly.
What weights are you guys running?
Old Sep 23, 2005 | 10:27 PM
jimbo74's Avatar
arizona shouldnt get too cold, so 20-50 should be fine
however, heavier oil will just mask noise, valvetrain chatter can eventually lead to a engine failure and if its that bad, you need t ohave it fixed properly
Old Sep 24, 2005 | 01:00 AM
live277's Avatar
oils
Try this link ,it might help on your choices a little more.bob200587 is correct on "family traditon"I used havoline and fram,but now I use GTX and mobil 1 filter
http://www.nordicgroup.us/oil.htm#The
Old Sep 24, 2005 | 06:27 PM
Old Sep 24, 2005 | 06:40 PM
Rivalred's Avatar
Vehicles that leaked oil (high mileage) when I used Quacker State and Valvoline the vehicles actually leaked more oil that usual. When I switched to Castrol, the oil leaks slowed down rather actually.
But all the reason and experience comes through the senses which is all relative.
Old Sep 25, 2005 | 04:01 AM
smiljko's Avatar
I'll be switching to MaxLife- what do you guys reccomend 10W40 or 15W40?
Thanks
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
chuckross1957
Sep 7, 2015 09:34 AM
calderp
Jul 27, 2015 09:58 AM
camo31_10.50
Jan 5, 2011 02:44 PM
