Trail welder question....?
Old Nov 15, 2005 | 09:26 AM
6lug's Avatar
I was wondering why no one uses gas welding out on the trail....It's a whole lot cheaper than a wire welder, but Ive never heard of it. I know having O2 and Acetylene in or on the car seems scary, but utility trucks carry this stuff all the time with no probs, so I was just wondering what you guys thought. Thanks Alex
Old Nov 15, 2005 | 09:35 AM
4Crawler's Avatar
I suppose it would be possible, but you are looking at around $300 for a small oxy-acetylene setup and you do have to be a little careful with acetylene tanks. They are a bit like a soda bottle in that the gas is held in solution and I recall you have to let them settle a bit before use. A couple of jumper cables, batteries out of 2-3 trucks and a few arc welding rods does the trick quite nicely:
- http://www.4crawler.com/4x4/CheapTri....shtml#Welding
Old Nov 15, 2005 | 01:02 PM
6lug's Avatar
Yeah, I do realize that they need to sit for a bit. I just see them on a lot of utility trucks, and a professional welder I know uses this setup out on the job, and doesnt have any trouble with it...I was just wondering what you guys thought about it. Plus, Im learning oxy acetylene welding right now, and Im doin pretty good. Just askin..
Old Nov 15, 2005 | 02:05 PM
4Crawler's Avatar
I don't think I have seen any one with that sort of rig on the trail, but I think I have heard of someone doing it. Just make sure it is all strapped down *very* securely. The O2 cylinder can turn into a rocket if you accidentally knock off the regulator.
Would be nice to have the cutting torch, too.
Old Nov 15, 2005 | 04:35 PM
6lug's Avatar
ha ha...def. wanna keep that regulator on both of those. Yeah, the torch was the other nice thing i was thinkin...thanks for the input
Old Nov 15, 2005 | 05:17 PM
4Crawler's Avatar
If you go that way, you might check with the local Forest Service folks and see if you'll need a special permit for the gas welder. Out in the National Forests here in CA, you are supposed to have a "burn permit" to operate a welder out in the woods (different than a campfire permit). I've never picked one up for my on-board welder, but unless it is set up you would not know it was on the truck. A couple of red and green gas bottles might be a bit more obvious, though.
Old Nov 15, 2005 | 06:04 PM
6lug's Avatar
yeah...good tip...thanks
TheBFA
Feb 15, 2020 06:55 AM
primordialbeast117
Dec 19, 2015 12:23 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
oldblue
Sep 28, 2015 04:07 PM
Toys4parts
Sep 26, 2015 01:56 PM
