$$ of tacoma e-locker?
Old Feb 2, 2007 | 06:30 PM
jjrgr21's Avatar
say the e-locker broke and had to be replaced how much do they cost and is toyota the only place to get them?
Old Feb 2, 2007 | 06:53 PM
Elton's Avatar
http://www.marlincrawler.com/htm/diff/pickup_diff.htm may get lucky and find a use one cheaper +
Old Feb 2, 2007 | 07:04 PM
Mojo_Risin's Avatar
http://www.car-part.com/
this is a junkyard search basically. Search under "carrier" or differential - might yield different results. This is how I foumd my e-locker for retrofit i my 4Runner.
john
Old Feb 2, 2007 | 07:47 PM
Ric's Avatar
Ric
Banned - User requested
what part of it broke ? I may have an extra actuator, i might be able to let go
heres something that might help ya http://ttora.norcalttora.com/wiki/in...tuator_Rebuild
Old Feb 2, 2007 | 07:50 PM
Elton's Avatar
i think he's just looking for a ball park on what one would cost
Old Feb 2, 2007 | 07:59 PM
Ric's Avatar
Ric
thats depends on what broke, as with mine, it was a wiring issue. about $100
or it could be the actuator, a used actuator, (if you can find one) $150 and up. thats about all i know, hopfully other will chime in with more and better info.
yotaman's Avatar
I'd say a complete used low pinion e-locker third member could be had for around $400-$700 depending on miles and shape. Some say a new one can be had from Toyota for around $900.
Old Feb 2, 2007 | 08:01 PM
Ric's Avatar
Ric
I'd say a used one would be around $400-$700 depending on miles and shape
are you talking the actuator ???? if so, i got a great deal.
https://www.yotatech.com/forums/show...cal+mini+truck
Old Feb 2, 2007 | 08:31 PM
yotaman's Avatar
No I'm taking the whole third member.
Old Feb 3, 2007 | 04:53 AM
jjrgr21's Avatar
it's not mine, a guy i go wheelin with, his 99 stays in the locked position, so i gues that would be the actuator
Old Feb 3, 2007 | 08:04 AM
tc's Avatar
tc
You can lock or unlock it by hand if that happens.
When I was looking at lockers last year, a used third was about $350-$400, but they typically only have 4.10 or maybe 4.30's so you're looking at probably having to regear too, so about $700 ready to go in the truck.
Old Feb 3, 2007 | 08:34 AM
ADH8796's Avatar
Can you lock it by hand also? How do you do this I'm interested to know until I get mine fixed.
Old Feb 3, 2007 | 01:44 PM
tc's Avatar
tc
Just reach under there and move the rod that the actuator attaches to. The electric is only needed to change "states" - it holds on its own once there. One of the guys in COTTORA has to slide under the truck while he's airing down to lock it, then unlocks it while airing up...
Old Feb 3, 2007 | 02:11 PM
ADH8796's Avatar
I assume that means I need to take the actuator off correct?
Old Feb 3, 2007 | 02:38 PM
Ric's Avatar
Ric
on mine, yes, you would have to remove the actuator to lock or unlock it by hand, then reinstall it.
Old Feb 3, 2007 | 03:13 PM
ADH8796's Avatar
why? Is my 98 E-locker set up different than yours?
Old Feb 3, 2007 | 03:19 PM
Ric's Avatar
Ric
my actuator looks like this
so yes, you would have to pull the actuator off to move the rod.
Old Feb 3, 2007 | 03:30 PM
ADH8796's Avatar
Oh now I get what your saying yeah I have the same actuator and yeah it sounds like it would be better to pull it off and rebuild it and see if it works after that.
Old Feb 3, 2007 | 03:33 PM
Ric's Avatar
Ric
yes, heres a great write up
Old Feb 4, 2007 | 06:04 AM
tacosalad's Avatar
e-locker cost
I have an 02 Taco TRD and the locker would not engauge. I was told that if they are not used they somehow seize up. I tried beating it with a hamer but that didnt do anything but give some satisfaction on beating something with a hamer. I had the actuater replaced with a new one which fixed the problem It cost new from toyota around $900. The dealer screwed up and covered the total cost even though the warrenty had run out. I did see one on E-bay that was used for $600 though.. good luck
