Suspension Upgrade-Regear, ball joint spacers
Old Feb 3, 2013 | 11:07 AM
KaiIndvik's Avatar
Hello-
So the time has come to upgrade my 89's stock (as in ORIGIONAL shocks, ball joints, everything). I'm thinking about a ball joint spacer kit for the front, procomp shocks, sway-a-way torsion bars, and then 33"x12.5xR15 tires.
Has anybody had any luck/experience with the ball joint spacers?
It seems great in theory, but I'm concerned about strength/durability. I'm not running the Baja 1000, but I take it out on the dunes/wheeling regularly.
And then also, I managed to pick up a 4.56 ring n pinion on craigslist for $40. If i run 4.56 in the rear, and 4.10 in the front will that cause any issues? Mostly on sand or mud.
Thanks in advance
Kai
Old Feb 4, 2013 | 07:08 AM
Bubba0's Avatar
I was wandering the same thing???
Old Feb 4, 2013 | 07:20 AM
waskillywabbit's Avatar
Tons of info if you'll search.
Nothing wrong with BJ spacers as I have them on my dd
http://www.wabfab.org/IFS-Lift-Kits/...-products.html
:wabbit2:
Old Feb 4, 2013 | 03:08 PM
KaiIndvik's Avatar
Ok, great. I had found different opinions online, so I just wanted to directly talk with someone who had experience with them. What about the gearing issue?
Thanks
Old Feb 4, 2013 | 03:18 PM
CHEEZE's Avatar
You have to have matching ratios or your tires will be spinning at different rpms
Old Feb 4, 2013 | 03:20 PM
KaiIndvik's Avatar
Right. But with a .46 difference, will it matter? Obviously it wouldn't work on asphalt, but in the sand or mud would it cause any problems?
Old Feb 5, 2013 | 05:41 AM
schwyter's Avatar
no bueno, amigo. your front and rear will not be spinning at the same RPM's, and they one will want to speed up or slow down to match the other, and something gotta give. just check out the classified section on here and match up your gears.
Old Feb 5, 2013 | 07:29 AM
4Crawler's Avatar
Don't look at the fractional difference in gearing, rather look at the relative difference, or 4.56 / 4.10 = 1.11 or 11%. That means the front tires will want to spin 11% faster than the rear tires, or for every 9 revolutions the front tires make, the rears will only make 8 revolutions. Basically the front tries will be trying to drag the rear tires along, would not drive very well.
Old Feb 5, 2013 | 11:17 AM
KaiIndvik's Avatar
Ok, thanks. Now final question...are the front and rear ring n pinions the same? Now I'm kinda thinking I should take my ring and pinion and put it in the front, then get a limited slip/locking 4.56 rear diff.
Old Feb 5, 2013 | 11:24 AM
4Crawler's Avatar
Nope, different sizes if you have IFS:
- http://home.4x4wire.com/erik/diffs/#types
Old Feb 5, 2013 | 11:27 AM
KaiIndvik's Avatar
Darn. Ok, thanks for everyone's help
aowRS
Sep 13, 2017 08:22 AM
Scottcrb
Mar 3, 2016 11:57 AM
jaretstuff
Oct 22, 2015 05:25 PM
Regency
Sep 6, 2015 05:47 PM
