suspension and body lift
Old Nov 2, 2008 | 09:39 PM
Yotapowa's Avatar
Hey, can somebody tell me a cheaper(not total chaos) commercial lift for my 86 that does not use blocks for the rear lift??
Also, can I do a 2 or 3 inch body lift without having to modify anything? I have been I may have to cut the hole for my shifter out to make it bigger, and adjust my steering column and stuff like that
Old Nov 3, 2008 | 11:00 AM
4Crawler's Avatar
I have some lift vs. tire size options on the web page below along with information on body lift installations and modifications needed:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
For the rear, longer shackles, add-a-leaves or lift springs are all viable options, depending on your needs:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ14
Old Nov 3, 2008 | 03:01 PM
tc's Avatar
tc
What size tires do you want to run?
Old Nov 3, 2008 | 10:04 PM
Yotapowa's Avatar
I have 32X11.5 now, and they rub a bit both front and back. I mostly want to get rid of the rub, and raise the truck up a bit. I won't be running larger tires for a long time
Sep 4, 2015 09:27 AM
upongame619
Aug 1, 2015 12:12 AM
Cabell
Jul 24, 2015 12:14 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
