steering stabilizer info needed
Old Aug 8, 2009 | 08:53 PM
SignorSchnitzel's Avatar
hey guys, i recently ordered a skyjacker steering stabilizer for my 92 toyota pickup, however i have the 3.4 swap and the bolts that replace the originals in the idler arm, to mount the bracket, are to long and run into the engine, so theres essentially not enough room. what i am wondering if there is like a skyjacker or rancho, that fits directly into the oem mounts? thanks
Old Aug 9, 2009 | 10:53 AM
4Crawler's Avatar
I think OME might have something that mounts up like stock, or get a new one from Toyota. Was your old one really worn out? Or you might try cutting the bolts down as short as possible and see if they will fit, or even replace them with like a flat head allen screw.
Old Aug 9, 2009 | 11:46 AM
RobD's Avatar
I have the OME steering stabilizer and a 3.4 swapped in, no problems with clearance whatsoever.
Old Aug 9, 2009 | 11:51 AM
desertcamper67's Avatar
I believe that Monroe's are a direct bolt on to OE mounts.
Old Aug 10, 2009 | 08:06 AM
well, as far as the bolts, you can look at it and tell it wont work if you cut them down, but that was my first thought, there just wouldnt be enough room for the spacer/nuts/ washers etc.. i will go look at these ome and monroes though, thanks guys
voiddweller
19
May 2, 2016 09:10 PM
Vargntucson
Jul 4, 2015 12:15 PM
BigArt70
Jun 30, 2015 09:51 PM
HALMAN
Jun 14, 2002 09:02 PM
