Pro Comp 33311 Leafs on an 1987 4runner ???
Old Jul 24, 2009 | 10:05 PM
orionhones's Avatar
[B]Does anybody know if the Pro Comp 33311 leafs would fit the rear end without modifications. They seem like they might be a cheap way to lift the rear end... Thanks for any advice you might be able to give!!!
Old Jul 28, 2009 | 07:23 AM
orionhones's Avatar
What I Found Out
No one has responded, but there seems to be a little interest in this matter, so I figured I would let those interested know that from what I have found out, it should work. I will let you know for sure after I put them on. May be a little while before I can, but I will update eventually.
Old Aug 8, 2009 | 11:00 AM
934rnr's Avatar
I did those springs they lift the rear up a lot.
My old bushings and bolts were hosed so I drilled the rear forward hanger to accept a larger bolt. Other than that no rear mods to put them in.
You need either 1.5" ball joint spacers in the front or a 4" lift. Mine sat pretty racked with a stock front end.
This is how mine sit with SAS and some 3" front springs.
Old Aug 10, 2009 | 10:09 AM
orionhones's Avatar
934rnr
like the lift 934rnr
MO transplant
Apr 23, 2023 11:58 AM
87turboPA
Jul 12, 2015 07:49 AM
shar
Jul 9, 2015 12:38 PM
tpd143
Jul 7, 2015 09:06 AM
Nickdigg
Jul 7, 2015 06:04 AM
