skyjacker ifs lift
Old Feb 24, 2011 | 05:25 PM
hellbilly's Avatar
Sweet I will look into that deffinatly thanks guys ill keep you posted
Old Apr 3, 2011 | 09:33 AM
Jacobeo5's Avatar
I have a few friends/acquaintances that run bracket lifts (tahoes, blazers, tacos, and runners). In my opinion and their's after seeing how the run and work. Bracket lifts are just glorified block lifts for ifs. You will gain no more travel or cycling of suspension. Your ground clearance will also not improve. The "ONLY" thing these lifts should be used for are tire clearance. Having said that the cost is not worth the cost. You are far better going with a BJ spacer and a small block/longer shackle combo in the rear, if all you want is the look and a small lift. This with a little bit of hammering of the pinch weld would get you far enough to run 33's. I understand you are getting the new gears cheap/free, but $1300.00 for a lift you are only gonna use for maybe a year is not worth the investment. Go with BJ/block hammer some stuff and keep the other parts in storage until you are ready for the SAS.
Flying91
45
Apr 11, 2024 04:39 PM
89fourrunner
Feb 17, 2016 06:52 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
basfire
Aug 14, 2015 07:58 PM
coffey50
Jul 28, 2015 10:55 AM
