skyjacker ifs lift
Old Feb 24, 2011 | 03:15 PM
hellbilly's Avatar
skyjacker ifs lift
im trying to find out if anyone has used the skyjacker 4 inch ifs lift for a 89-95 truck i have a 92 extended cab and just want some opinions on this lift kit im not looking to do an sas just yet im gonna run 35x1250 tires on a 15x10 wheel any advice would be great thank you
Old Feb 24, 2011 | 03:31 PM
2DoorRunner's Avatar
I installed a bracket lift on my runner. Havent even driven it yet and i dont like it.
Although plenty of people run them without issues, so it wont hurt anything.
And SOMEONE will say something about running 35s on ifs. Nothing wrong with that either. Just be prepared to replace parts alot sooner, and carry spares on the trails(if you are actually wheeling it.
Personally if i was in your situation i would run 31s/33s stock height, or with bj spacers untill i could afford a sas.
Old Feb 24, 2011 | 03:37 PM
xxxtreme22r's Avatar
35 12.50 15's will fit on a stock IFS with no lift with 3.75 backspacing on the wheels with a small fenderwell massage. Or so I've been told.
Old Feb 24, 2011 | 03:45 PM
hellbilly's Avatar
yea ive thought about running 33s and just trimming a little i dont want to chop my truck up to much i eventually will def do an sas im running 31s on a 10 inch wide wheel right now and its alright my rear springs are shot tho but it wheels ok
Old Feb 24, 2011 | 03:48 PM
33's will fit with no rubbing at all. Or at least they should. Assuming the correct backspacing anyway. What that is not sure, but there is a ifs wheel tire size thread ya might wanna check out.
a 10 wide wheel is not the best thing for airing down a 10.5 tire, but should work on with a 12.5" tire but not as well as an 8" and 12.5 tire.
yoder519's Avatar
i run 35s on bj spacers and a 2in BL. they did rub at flex on the pinchweld, til i cut the fenders and pinchweld out
Old Feb 24, 2011 | 03:55 PM
hellbilly's Avatar
do those spacers bolt up pretty easy?
Old Feb 24, 2011 | 03:56 PM
BJ spacers? Took about 2 hours on my buddies truck, and we had no clue what we were doing.
Old Feb 24, 2011 | 04:04 PM
if he's not willing to cut/pound some pinchwelds to clear tires, I doubt he's gonna want to cut the upper control arms to put the ball joint spacer in. And I think you have to cut two tabs or something like that for the bracket lifts as well, but I could be wrong about that.
Old Feb 24, 2011 | 04:08 PM
I had to cut the stock a arm mounting location off my 4runner. But thats because i was to lazy to drop the diff completly
And if he iant willing to do that stuff, i dont know how he will ever get the balls to hack off the ifs for a sas!
Old Feb 24, 2011 | 04:45 PM
hellbilly's Avatar
Actually I have no problems doing an sas i did one on my friends Chevy and it was bad ass I just don't want to hack the sh** out of my fenders I like the way it looks just looking for opinions on the ifs lift not whether I have the balls to do something thanks for the comments but your getting off the subject this isn't Facebook
Old Feb 24, 2011 | 04:50 PM
Tried to stay on the subject, just pointing out the need to cut the upper control arms for the spacers. Somewhat assumed you didn't want to cut anything up except to do an SAS. Sorry.
But anyway, pounding a pinch weld isn't gonna change the look of the fenders.
Old Feb 24, 2011 | 04:55 PM
hellbilly's Avatar
I kno I'm just trying to keep the ride somewhat decent and a Lil more ground clearance to do some mild wheeling I'm not gonna do the sas till I move back to Washington state there isn't to many wheeling spots in Ohio so I need something dependable and a Lil more tuff for my camping trips plus I got some 529s for free from a friend and they are for the ifs diff so might as well use em but 31s will be to small as its my daily driver
Old Feb 24, 2011 | 05:01 PM
hellbilly's Avatar
The skyjacker lift with the rear leaf springs not blocks is only 1300 bucks I didn't think that is a bad price just don't kno if any one has had good luck with the kit
Old Feb 24, 2011 | 05:07 PM
87hillbillyoter's Avatar
you could get a sas kit for that. although in the end the sas would cost more, you will be kicking yourself for buying an ifs lift instead of going to a solid axle. just my $.02
Old Feb 24, 2011 | 05:09 PM
hellbilly's Avatar
How do the sas perform on the street. When I did my friends Chevy it was never driven on the street it was strictly a wheeler
Old Feb 24, 2011 | 05:13 PM
just a little rougher on the road. but its well worth it for the performance gained offroad
Old Feb 24, 2011 | 05:15 PM
hellbilly's Avatar
Yea I bet but are they safe for street I do a lot of highway driving
Old Feb 24, 2011 | 05:17 PM
plenty safe. they even came stock from 79-85. nothing to worry about safety wise. plus, theres less parts to break
Old Feb 24, 2011 | 05:19 PM
plenty safe assuming done correctly and not booty fabbed and welded by an amateur.
