Silencing Metal Spacers
Old Jul 21, 2004 | 07:04 PM
914runner's Avatar
Did you do the install or did a shop? If you are going to take the whole strut apart you will need a spring compressor.
Old Jul 21, 2004 | 08:17 PM
cubuff4runner's Avatar
That is exactly where your noise is comming from. Did you put new struts on? If so did they come with new bushings? Most struts can have slighly different bushings so the threads are made to stop to fit their specific bushing. One quick fix is to add a couple of washers on top of the existing one. It will only take a few minutes because you won't have to compress the spring or remove anything except fot the top strut nut.
Old Jul 22, 2004 | 06:41 AM
03TRDBlack's Avatar
I did replace the struts. I had the tokico shocks that came with it, and traded them out for a set of Bilstein struts. So all I have to do is remove that top nut and put some washers on? Nothing will come apart will it?
Old Jul 22, 2004 | 06:46 AM
bamachem's Avatar
That's EXACTLY where the noise is coming from. I made the same mistake on mine. :pat:
Don't take the setup apart. You take that nut off along w/ the washer, put the bushing on, then the washer, followed by the nut and re-tighten. It's a 5-min job per side. You don't have to take the strut assembly apart to do it.
Old Jul 22, 2004 | 10:41 AM
  #25
03TRDBlack's Avatar
Got the problem fixed, or at least temporarily. I went out and got some stainless steel washers and added them below the nut. I tightened it down and no more noise!!
Old Jul 22, 2004 | 11:39 AM
  #26
By the looks of the picture it appears that you are missing the top bushing(the one that goes directly underneath the large washer that you can see).
Old Jul 22, 2004 | 11:58 AM
  #27
r0cky's Avatar
YES! Is that the "rubber grommet" you were talking about? I totally misunderstood which rubber piece you were referring to, but the rubber bushing is exactly what was/is missing.
Old Jul 22, 2004 | 05:00 PM
  #28
03TRDBlack's Avatar
Yes, that is what is missing. I replace it (at least temporarily) with a stack of stainless steel washers. The noise is gone!
Old Jul 22, 2004 | 05:10 PM
  #29
sschaefer3's Avatar
This is without a doubt the issue, have them put the bushings back in because that is how the shock shaft flexes, your fix is limiting the shaft flex.
Old Jul 22, 2004 | 07:16 PM
  #30
Steve is right. Make sure that you get the bushing in there as soon as possible, especially before giving it a beating off-road.
Old Jul 22, 2004 | 07:23 PM
  #31
r0cky's Avatar
I agree ... who installed it? If it was a shop, they should have known to put that piece back in ... I hope whoever it was still has it.
Old Jul 24, 2004 | 08:12 AM
  #32
03TRDBlack's Avatar
No, actually they don't have the bushing anymore. I think they gave it back to me and I sold it with the old shocks. They are however getting me new ones and are going to put it on for me. (Free of course!)
Old Jul 24, 2004 | 11:14 AM
  #33
r0cky's Avatar
well, that's really good that they'll order you new ones and put them on for free! i hope if they've done that on other trucks that those owners have realized it before anything was injured!
(oh, and your avatar looks awesome, man!!)
ashamsuddin
17
Jul 22, 2024 03:59 AM
4x4YOTA
Aug 23, 2016 09:08 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
89YodaRunner
Sep 30, 2015 02:18 PM
crash813
Sep 27, 2015 07:15 AM
