Short travel after lifting
Old Jul 13, 2013 | 11:51 AM
whitecollarredneck's Avatar
I recently installed 2" ball joint spacers on my IFS for my front lift. I looked the other day and noticed that I only have about 2" before I hit my bump stops. How different is this from stock? It seems like I lost some travel but I didnt check how much I had before I installed it.
Old Jul 13, 2013 | 01:02 PM
bone collector's Avatar
did you put on longer shocks to compensate for the added height?? if not you will be having a lot of lower ball joint problems soon.
https://www.yotatech.com/forums/f116...joints-269220/
here is one option.
https://www.yotatech.com/forums/f116...shocks-267013/
some pictures would help explain what you are truly questioning
Old Jul 13, 2013 | 01:09 PM
here is one option.
Yeah I have longer shocks. Basically what I mean is the lower control arm is only about 2 inches below the bump stop. So if i drive over a speed bump I'm pretty much hitting them. Not only does it make rough terrain uncomfortable, but I still have like 4 inches of travel on my shocks. I'm just wondering if it's normal to have so little travel.
Old Jul 13, 2013 | 07:00 PM
Inu's Avatar
Inu
Remeber the arms a lever. If theres 2 in under the stop theres more like 4-6 at the wheel.
Old Jul 13, 2013 | 11:10 PM
highonpottery's Avatar
Short travel up or down? BJ spacers increase down travel over stock. If you cranked your tbars to add more than the 1.5"/2" spacer then this is your reason because there is so much preload on the bars and they don't want to twist. Theres also a limit with how high you can go due to CV angles. What are your fender lip to axle centers measurements?
Old Jul 15, 2013 | 07:11 AM
derockus's Avatar
i can tell you my stock IFS only has about 2" between bump stop and a-arm while sitting in the driveway. like people say, the wheel travel is longer than the bumpstop travel.
you can also get low-profile bump stops. Check this thread https://www.yotatech.com/forums/f129...mpstops-75740/
you get more travel but when you bottom out it's harsher because there isn't a big cushy bumpstop to absorb the impact of bottoming.
Old Jul 15, 2013 | 02:03 PM
Having heard this i think this is much less of a problem than i thought. I'll probably do low profile ones just so i can use the full travel of my shocks. Gotta get that last little bit of articulation lol.
Old Jul 15, 2013 | 02:20 PM
derockus's Avatar
Hey, you paid for it, may as well get it!
Let us know how the ride feels after.
okamikai
Apr 30, 2018 10:19 PM
94ofCanada
Aug 14, 2015 06:37 AM
genuinegemini
Aug 3, 2015 04:56 PM
SMOD
Jul 27, 2015 01:45 PM
Cabell
Jul 24, 2015 12:14 PM
