Removing the double cardan U-Joints
Old Oct 26, 2006 | 11:54 AM
Crazychopstick's Avatar
I've read the "U-joint" articles on 4x4wire and Pirate4x4, but I still have a question.
Is there a certain method(area) to smack the 2 U-Joints out the double cardan joint?
There really isn't much room to smack the yokes, and I feel like I'm taking alot of metal off the driveshaft.
Old Oct 30, 2006 | 06:31 AM
Bump.
I just contacted my local Stealership and they informed me that they don't even replace the U-Joints in the double-cardan.
They replace the whole double-cardan itself: $900.
Should I not have taken apart this driveshaft or does Toyota feel that they can just charge more and save time by replacing the whole shebang?
Has anyone even taken apart a 3rd gen(4WD) driveshaft on here?
Old Oct 30, 2006 | 06:41 AM
trf4x4's Avatar
I just had my repaired on my 98 4R. The stealership told me the same thing. I looked all ove Oklahoma City, trying to find someone to replace the CV-Ball. That is what was wore out on mine. I found a place in OKC call Blumenthal Performance. Their # is 405-552-8688. I took mine to them, and they did'nt even blink twice. They replaced all 3 U-Joints plus the CV-Ball, balanced and painted it for $126. I did'nt argue with that. The dealer ship told me they don't repair them. They put a new Drive shaft in. I hope this helps.
Old Oct 30, 2006 | 06:45 AM
Thanks for the quick reply!
How could you tell that the ball was bad?
I'm thinking about replacing mine since I already have everything apart!
Old Oct 30, 2006 | 06:54 AM
trf4x4's Avatar
I had a vibration when I got over 65mph. It took me a while to narrow it down to the CV-Ball. While it was still on the truck, I crawled under it and pushed and pulled on the drive shaft. I had very little play in the drive shaft. I trcked it down to the front of the drive shaft. I got a flsh light and shined it up to where I though the play was coming from. It turned out to be in the CV-Ball. It was only about 1/32 of an inch. When I took it off the truck I could'nt get it to move at all. So I drove the truck in 4WD with out the rear drive shaft in. I had no vibration. So, Even though it was'nt much. It was enough to vibrate. I know this was kind of long, but I hope it helps. Tommy
Old Oct 30, 2006 | 06:57 AM
4Crawler's Avatar
Some information on this page:
- http://www.4x4wire.com/toyota/tech/cvmod/
I tried to tear one apart and gave up after a few hours. I took it to my local driveshaft shop and they fixed it up for about $100 including new parts. Well worth the money spent IMHO.
Old Oct 30, 2006 | 07:03 AM
Thanks guys.
Is there a site I can get the U-Joints with the zerks on the caps?
The joints I have, are the ones with the zerks that come out from the center of the cross. I'm not sure if there will be clearance issues or not.
Old Oct 30, 2006 | 07:06 AM
trf4x4's Avatar
I don't know about you can but the u-joints. I would just take it to a shop and they will have all the replacement parts. It's alot easier that way.
Old Oct 30, 2006 | 01:31 PM
Man the ones I have are not going in!
The caps are the same size but no matter how I hit it, they won't stay in!
Old Dec 15, 2009 | 12:12 PM
OldManYota's Avatar
ok, on my 81, the factory repair manual says to replace the whole front driveshaft if any problems are found. This is not completely true. If you place one hand on one side of the double cardan and one hand on the other side, try moving side to side, up and down. If there is play, the CV joint inside the double cardan is toast. If it is solid it is still good. Roll the joints like they would if they were installed. If smooth ok.
To disassemble joints first remove all zirc fittings from caps, then pop out clips on u-joints from inside double cardan. To remove the clips i use to identical smaller flat-head screw drivers, holding the handles together, with the tips on each side of the clip, then lightly tap the handles of the screwdrivers with the side of the hammer so you hit both handles at once. This usually pops out the clip. The factory repair manual states that u may have to tap down the caps a bit further to get the clip out, but i've never had that problem. Use a drift punch slightly smaller than the caps, and hammer down right on the cap until opposite cap pops out. then use drift punch to hammer back the other way, right on the u-joint. when all four caps are out on each joint then you should be able to seperate all peices.
Inspect the cv joint. i've found many front drive shafts where the cv is really damaged. Usually the cup in the CV joint is damaged, and sometimes the ball. Driveshafts damaged at the cv joint are usually toast, however i've used a die grinder to knock down any spots on the ball that prevent proper operation, re-assembled, and they worked perfect. however some are so damaged at the cup side that this cannot be done. Time to replace the entire driveshaft.
I recommend installing new u-joints, with the Creeper Joints from Trail-Gear being my u-joint of choice.
To re-assemble, loosely fit all pieces together, including the u-joints without caps or clips, ensuring the the CV joint fits together properly, then tap in each cap about 1/4". First tap in the caps on the Double-cardan then do the outer caps, ensuring that the u-joint fits into the caps without knocking over the roller bearings inside the cap. Install the clips as you go.
When all is back together, do all the hand tests listed above. No play side to side or up and down, and the double cardan rolls like it should, smoothly.
As for the Zirc fitting on the caps instead of at the center of the u-joint, i used old caps i had, that were that way already.
If your caps are so loose they wont stay in, then you probably dont have the right u-joint.
I hope all this helps.
Old Sep 22, 2011 | 02:33 PM
Nikodemus's Avatar
Rockford Driveline (http://www.rockforddriveline.com) sells every part you need to completely rebuild the Toyota front driveshaft. They also sell a complete NEW shaft for under $600 (plus s&h).
Jcrawl94
10
Oct 24, 2015 04:34 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
nebulae87
Aug 27, 2015 02:45 AM
CratesCruiser
Aug 23, 2015 06:12 AM
AppalachianOffRoader
Aug 12, 2015 12:55 PM
