Spring under axle setup?
Old Aug 14, 2011 | 12:44 PM
Diggity's Avatar
I was hanging around in the garage yesterday and I started to wonder about swiching from the spring over leaf spring/axle setup to the swing under setup. Has anybody done this? Are there any potential drawbacks or issues I'll have? I've got an 85 4runner, with the trail gear 3 inch lift. It's a bit tall now, and I'd hope to gain a lower center of gravity. Just looking for thoughts on the feasibility, or potential problems I'll have doing this.
Thanks
Old Aug 14, 2011 | 02:06 PM
waskillywabbit's Avatar
Makes your 3" lift kinda pointless IMO.
:wabbit2:
Old Aug 14, 2011 | 02:19 PM
SpecialScottie's Avatar
Would be easy in he back. The front might be difficult to clear the steering
Old Aug 14, 2011 | 02:57 PM
85gijunk4x4's Avatar
brings the whole truck, frame and everything, closer to the ground
you gain lower center of gravity, but you also loose ground clearence.
like said above, rear is simple, but front may interfere with the steering
Old Sep 25, 2011 | 05:57 PM
Gravel Maker's Avatar
FormerVendor
You haven't mentioned your purpose for this truck...
If it is a desert truck with long travel springs it makes perfect sense...Thats the way its done when you want to go fast, you need to keep the weight down to get the travel or the bed is 6' in the air at ride height...
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
nvdesertrunner
May 11, 2020 08:18 PM
jerusry
Oct 19, 2015 05:28 PM
priest16
15
Aug 6, 2015 07:43 AM
