powering my winch
Old Feb 25, 2010 | 04:58 AM
85chevyota's Avatar
powering my winch
hi im new to owning a winch and i had a few questions. first of all how do i need to wire my winch up? i hooked it straight to the battery and didnt not have my truck running and it killed my battery in about 30 seconds. second do i need another battery thats stronger or two batteries with a switch to switch from one to the other? any information you guys can give me i would appreciate.
thanks
Old Feb 25, 2010 | 05:25 AM
dropzone's Avatar
Fossilized
welcome to YT:
google--
http://www.offroaders.com/info/tech-...ch-install.htm
http://www.jpmagazine.com/techarticl...ing/index.html
http://images.google.com/images?hl=e...ed=0CC4QsAQwBA
http://www.tpub.com/content/hummer/T...-20-3_1076.htm
plus a ton of others
you need to have a good battery (more likely duals) etc...lots of good resources out there...your winch should have also come with some directions.
It is a very high amp draw motor....
Old Feb 25, 2010 | 05:32 AM
85chevyota's Avatar
well i bought the truck and had the winch but was not connected and just got to put it back on after 3 years. lol
its a warn MX6085 from back in 1985 so i cant find any bit of info on it. thanks for the links though
Old Feb 25, 2010 | 06:20 AM
MB4runner's Avatar
Don't run the winch unless your truck is RUNNING! You need the alternator going to recharge the battery.
Second, a big battery will help, but really it's the alternator that comes up short since it doesn't put out very much at idle. You may have to hold the RPM at 2,000 if you are doing hard pulls.
Old Feb 25, 2010 | 06:43 AM
claudebadly's Avatar
have the engine running, and to keep those rpms up without having to pop the hood/have someone in the seat, ive seen people put in a second throttle cable, and run it to a bicycle speed shifter to set the throttle at a certain rpm. usually 2000 to 2500. then run the winch
Old Mar 1, 2010 | 04:19 AM
85chevyota's Avatar
this weekend i had the winch mounted down and tried it out. i kept my truck on and it worked without killing my battery and i didnt have to rev the engine at all. thanks for the help guys. i have another question now, i want rope instead of cable but the synthetic rope is too exspensive. anybody know of a substitute?
Old Mar 1, 2010 | 07:56 AM
Gerdo's Avatar
Winch Rope is made from one of two types of rope. Either Amsteel Blue or, my favorite, Tech-12. The Tech-12 is very heat resistant. I have found on ebay.
Then you splice in your own eyes http://www.samsonrope.com/site_files/12S_C2_EyeSpl.pdf using these http://www.jamestowndistributors.com...+Aluminum+Fids
Old Feb 20, 2011 | 12:59 AM
wyoming9's Avatar
Red face
All I can say is if it killed your battery in 30 seconds you must have a tiny battery.
What kind of pull where you making?
I winch with the truck shut off now and again.
I have also used the 9.5 ti just from a battery this pulling a 5000 pond truck on the level in the shop.
I also use #1 welding cable for winch power
Jun 1, 2021 01:51 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
Sidherish
Aug 2, 2015 01:42 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
Vargntucson
Jul 4, 2015 12:15 PM
