new gear install question
Old Sep 15, 2004 | 11:29 AM
forty4's Avatar
if i install new gears in my 84 4runner to i have to buy that install kit to properly install the new gears or can i get buy with just putting in the gears?
Old Sep 15, 2004 | 11:54 AM
fourwd1's Avatar
If YOU are doing the work yourself you can do it any way you want.
If a reputable shop is doing it, they will (should) insist on using a kit.
Old Sep 15, 2004 | 04:45 PM
forty4's Avatar
so i'll be alright just changing the pinion and gear?
Old Sep 15, 2004 | 09:05 PM
ZUK's Avatar
ZUK
In the front end.....ya, you can get away with old bearings and a crush sleeve mostly because it sees only 1% use and no highway speeds....
The rear is more "critical" cause of the full time use/abuse/heat it sees. The pinion bearings are usually quite worn so a master kit is a wise investment. In addition, a solid colar for $30 is money well spent for durability.
US GEAR would be the strongest and most dependable......this is assuming that the actual install was of pro quality. See my webpage for some insight. If you give it a shot and screw things up then I offer my pro install services to undo your "handywork" ZUK
Old Sep 15, 2004 | 09:23 PM
jimbo74's Avatar
unless YOU KNOW WTF! you are doing, i would touch gears, they need to be set up properly or bad things happen
Old Sep 16, 2004 | 06:35 AM
toy283's Avatar
Then there is the possiblity of damaging bearings with removing them from the carrier or pinion. I've had bearings I thought were good come apart on the press during removal. So, even if you don't plan on replacing them, don't start unless you have replacements and money lined up and available. BTDT.
Old Sep 16, 2004 | 03:03 PM
ZUK's Avatar
ZUK
TOY283 said.........I've had bearings I thought were good come apart on the press during removal.
you didn't blame the bearings for that, did ya?
Old Sep 20, 2004 | 07:40 PM
ZUK's Avatar
ZUK
Earth to forty4........
Old Sep 20, 2004 | 07:42 PM
yotafool's Avatar
i say get some master install kits, and leave the work to professionals
Old Sep 20, 2004 | 08:36 PM
toy283's Avatar
Nope. No one to blame but the mechanic (me). My point though is to be prepared for any eventuality. Nothing sux worse then getting halfway into a project and not have what you need to finish.
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Coreyr384
Jul 10, 2015 11:13 AM
