Which lift is cheaper?
I'm thinking about getting a lift, should I consider a; front stage 1-2 pro-comp lift with a rear leaf spring conversion with taller leaves, or, a full pro-comp, skyjacker, and other brands, lift-kit. I wanna get a 1-2'' body lift also, but I have an auto
I hear the rear leaf spring conversion is cheaper, and less of a hassle than a lifted rear coil set-up.
What type of wheeling are you looking into? For example, you could fit 33's, save a whole lot of dough on the lift by visiting www.4crawler.com, and spend the money on a lockers/gears whichh will really make your truck more capable.
Frank
Frank
Normal wheeling like driving in mud, puddles, water; that kinda wheeling. No hardcore off-roading. I'll get 4:88 gears once the 33's are installed. Lockers, not quite, since I plan on using my yota for a daily driver. I'll probably get a used LSD.
33's are easy to fit, you don't need a 4" lift.
Go to www.4crawler.com and you find an effective and economical solution.
Frank
Frank
I had a 93 with a 4" Superlift and 33x12.50 Trxus M/Ts. It was nice, and taller than those "tiny hondas". It's a good setup. Even if you aren't going to be off-roading a lot, but want the 4" of lift, make sure you get one that has the one piece subframe. Those are the Superlift and either Tuff Country or Trail Master.
Originally Posted by garrett1478
whys does the fact that you have an auto affect a body lift?
the shifter has a linkage that must be adapted to work... the manual shifter is part of the tranny and works independent of the body
Definitely get the 1 piece drop brackets. That means Superlift, TuffCountry, SkyJacker and Black Diamond. Trail Master and Procomp have bolt together drop brackets.
is this only for 2nd gens or what?
http://www.4crawler.com/4x4/ForSale/...html#ATbracket
3rd gens are fully adjustable, so that is not an issue. Good recipe fro fitting 33" tires on my web page:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Originally Posted by fo_runner
The problem is, I like to be king of the road by having a taller rig than those tiny hondas
It sure helps to see over them cars in a parking lot.
choppe777
May 16, 2016 08:00 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
