knuckle leaking??
Old Jul 16, 2008 | 09:15 AM
KreepyKrawler's Avatar
knuckle leaking??
hey guys i have some toyota 84 pick up axles and on the front one the passenger side knuckle leaks just a little on to the knuckle ball is it just the felt pad or do i have to buy the whole knuckle service kit? if so does it require any specialty tool?
Old Jul 16, 2008 | 09:21 AM
toyota-erik's Avatar
If its leaking, then the axle seal is toast. the felt pad just keeps dust out of the knuckle.
allprooffroad.com has a nice upgrade kit.
Old Jul 16, 2008 | 09:22 AM
fillsrunner4's Avatar
To replace the pad youll have to take the entire knuckle off.
Would be a good time to give it a full rebuild if you go this route.
The knuckle should have a little grease on it but should not be a leak with grease everywere.
Youll need a good set of tools to rebuild the knuckle but its definetly possilbe for anyone to do.
Search knuckle rebuilds online and you can find the step by step
Old Jul 16, 2008 | 09:24 AM
Allpro, trail gear (sells the most complete), and marlin sells it also.
Not a bad time to replace wheel bearings also.
Ive got a Trail gear kit for sale with wheel bearings and heavy duty rock rings if your interested PM and ill cut you a deal.
Old Jul 16, 2008 | 09:47 AM
dirtoyboy's Avatar
Yup...check out those wheel bearings. I would recommend replacing them with OEM Koyo or NSK bearings (unless you like changing them on a regular basis)
Check out MarlinCrawlers heavy duty axle seals..they are BEEF! no more birfield soup.....
Old Jul 16, 2008 | 09:48 AM
x2 on the heavy duty seals from marlin the things are beef compared to stock
Old Jul 16, 2008 | 04:19 PM
4rnnr33's Avatar
i would say get the marlin knuckle rebuild kit or oem. dont go to all pro unless you want the worst customer service that you can get
Old Jul 17, 2008 | 04:49 AM
dirtoyboy's Avatar
and why is this? you cant just post something like that without backing it up!
glowz825
Jan 25, 2022 09:28 AM
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Ernie217
Aug 14, 2015 05:25 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
