Installing older rear axle...???
Old Jun 2, 2005 | 09:25 AM
BajaRunner's Avatar
Hey I have a friend who is willing to sell me his 6 cyl rear axle from a 92 Toy pickup. He has 4.88 gears too.
Would this axle work? I wanted to do leaf springs anyways.
What is the problem with the older axles bolting up to the driveline?
Old Jun 2, 2005 | 09:58 AM
99_Runner's Avatar
There shouldn't be any problems with it bolting to the driveline. If you didn't want to do the leafs right away, then just swap the third members out for now, then swap back later after doing the leaf swap.
Old Jun 2, 2005 | 10:26 AM
BajaRunner's Avatar
So lets forget about the leafs for now...
Just the gearing part.... 3rd member... That will literally just bolt up to my current axle? Which Toy 3rd members bolt up perfectly?
Old Jun 2, 2005 | 11:32 AM
4RunnerKid's Avatar
isn't your rear axle wider than the 92 rear axle? i know the 92 is 58" WMS to WMS...
Old Jun 2, 2005 | 11:48 AM
BajaRunner's Avatar
Well, yah mine is ~61" but, I was thinking I would just add wheel spacers....
Im just thinking about swiching out the 3rd members and keeping my axle cause I m still not sure if I'll be doing leafs or not.
Old Jun 2, 2005 | 11:57 AM
jimbo74's Avatar
swapping out the thirds is a dircet bolt in swap... might need to look out if there are any type of speed sensors in that housing, i dont know if toyotas have them there or not, but some axles have this as an issue
Old Jun 2, 2005 | 06:22 PM
BajaRunner's Avatar
So your saying if you had 3 axles .... a 4cyl from a 81, a 6 cyl from a 93, and a 4 cyl from 95............ you could interchange all their 3rd members?
Old Jun 2, 2005 | 06:35 PM
Napoleon047's Avatar
yes, they are all interchangeable. only the e-locker, t100, tacoma and tundra 3rds are different
Old Jun 2, 2005 | 07:11 PM
sschaefer3's Avatar
yeah.
Old Jun 2, 2005 | 07:25 PM
EWAYota's Avatar
refresh my memory, whats the difference between a 4 cyl 3rd member compared to a 6 cyl? and correct me if im wrong, but the swapping is ONLY for the rear axle correct?
Old Jun 2, 2005 | 09:41 PM
4Crawler's Avatar
Exterior of the housing is different:
http://www.4crawler.com/4x4/4R_TechInfo.shtml#DiffTypes
Old Jun 3, 2005 | 08:24 AM
99_Runner's Avatar
The V6 diff is stronger, but not to much. Yea, I would only swap rear-to-rear and front-to-front. You might be able to do front-to-rear or rear-to-front, but I'm not sure.
Again, I would just suggest swapping the thirds, get new gears for the front third, and do a leaf swap later using the same axle that's in the Runner right now.
Old Jun 3, 2005 | 08:45 AM
BajaRunner's Avatar
Cool man, thats probably what I'll do then.
So when you get your stuff re-geared, is it easier to just bring the shop the third members....
This stuff I never even thought about... weird.
Old Jun 4, 2005 | 08:52 PM
arjan's Avatar
If you have the Elocker then your housing has a notch in it. You could bolt in the rear of the older runner/truck, but you'll have to seal the edge and remove a couple of studs. Not ideal, but you'll likely get away with it for a while.
Old Jun 5, 2005 | 09:35 AM
BajaRunner's Avatar
D'oh!
Yeah, I was wondering about that...
I do have the Toyota elocker
Old Jun 6, 2005 | 03:04 AM
99_Runner's Avatar
If you've got the E-locker, then I would regear that one while you are doing the front, otherwise you lose your locker. I guess you coulddo the swap for a little while, until you could get your rear 3rd regeared, but again you would lose the rear locker. Not sure if that is something that I would want to do. Just my $.02
Old Jun 6, 2005 | 06:40 AM
mt_goat's Avatar
I believe there are some limitations to regearing an e-locker diff.
Old Jun 6, 2005 | 06:53 AM
arjan's Avatar
The toyota 4.88s won't fit, but you also get those aftermarket and they do fit.
Old Jun 6, 2005 | 12:08 PM
kyle_22r's Avatar
nope. any V6 gearset works in an E-locker third.
a toy 4.88 third will interchange with any other 4cyl or v6 third but you can't regear it with anything other than the factory gearset. however, just by looking at the one in my garage, i can tell that it'd be a lot harder to break than an aftermarket set of 4.88s, as the pinion offset is different, allowing it to have a thin ring gear and a big, beefy pinion.
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
