how strong are the diff gears?
Old May 25, 2003 | 09:00 PM
Robinhood150's Avatar
How strong are they in reverse when the load is on the coast side (I believe it's the coast side)? If I go up an obstacle backwards do I have to worry about grenading my rear diff (don't ask me why I'd go up an obtacle backwards ) Would the axle break first, or the diff? From the Pirate thread I posted in Cebby's regearing post, it sounds like my 4.88 diffs are the strongest toyota installed.
Steve
Old May 25, 2003 | 10:20 PM
jx94148's Avatar
One of your front CV joints would explode before either of the ring and pinions flinched. Only if your R&P was howling like a coyote due to severe wear/ lack of oil would it go first. Its intentionally designed that way.
Aftermarket gears may be a different story. Still I think it would take a lot of wear to make even the poorest quality gear go before a CV.
Like i've said before, i'm no physics professor. FWIW
Old May 25, 2003 | 10:48 PM
Yeah, I figured the CVs would die first, but the reason I ask is because I've heard of people chipping a tooth while trying to pull people out in reverse. People say to try to tow people in forward gears.
I can imagine that if I have a locker in the rear then it's possible to put more stress on the rear axle than the front axle, circumventing the CV problem. It's more academic I guess, I was just curious, though.
Old May 26, 2003 | 05:35 AM
44Runner's Avatar
Pulling people out in reverse is definately a bad idea in a stock IFS rig or, say, an FJ-80, due to both diffs running on the coast side in reverse (all those rigs mentioned have reverse cut fronts). I you were crawling (i.e. no hopping that normally takes out CVs) I would not be surprised to see a front R&P take a crap. People grenade front R&Ps all the time so it would not be unusual. So in short, I would bet on the front going before the rear....
Old May 30, 2003 | 12:01 PM
4runner4ever's Avatar
Using your gears backwards makes em like 30% weaker due to the teeth design. Try to avoid,especially with a locker, to overstress them.
I've allready had to replace the R&P on my own vehicle several times and some others, even a 2WD once!
Since I use a high pinion front diff I never had problems in the front again. No cure for the back though
I'm thinking about swapping in a Landcruiser diff. They seem to be idiot proof and never fail.
I think that solution would fit me..:pat:
Old May 30, 2003 | 01:02 PM
44Runner's Avatar
Are you talking about a whole Landcruiser axle? Because the only diff that would fit would be the front high pinion one which of course would be a terrible idea for a rear axle...
what do you mean by "no cure for the back?"
Old May 31, 2003 | 12:07 PM
No cure for the back: I mean to say I swapped in everything from original to aftermarket stuff. The strongest seem to be the V6 style E locker. (the only one I haven't broken yet).
I plan on swapping the whole rear axle since the R&P are I believe 9" and they will never fit an 8" axle. I can get a labndcruiser rear axle with e locker for some 1000 USD. Doesn't seem to be a bad deal. Have to add up a new 4.88 R&P though.
And I allready are using the high pinion diff up front. My front prop shaft really likes the new smaller angle from the high pinion.
Now I can add a further 2 inches off lift without angle problems.
Old May 31, 2003 | 01:20 PM
44Runner's Avatar
So you have an FZJ-80 entire front axle in the front of your rig, or just the diff?
FZJ-80 rears are freakin nice. e-locker, bigger ring gear, and full floating. I want one too!
Old Jun 1, 2003 | 01:46 AM
Actually I swapped the front axle, panhard bar, both the large carrier arms and the swaybar from a FJ70 series. And added an ARB. The coils are from a 80 series front axle.
This is almost identical to the FZJ80 but a bit smaller. I used two 1 1/4 inch spacers to add some track width. And welded everything on so I have a 3-4 inch lift.
I've got all the parts needed for swapping disc brakes onto my drum brake Runner axle, but the FZJ80 is a lot stronger.
So considering my engine swap will provide me some 210 hp I think I'm gone go for the larger R&P. Just don't know what to do with my current 8" E-locker. Sell it and use the cash for the 80 rear axle or save some money and put the E locker in my Suzuki project.
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
priest16
15
Aug 6, 2015 07:43 AM
yourrealdad
Jul 29, 2015 11:08 AM
Athansinis
Jul 27, 2015 08:38 AM
