"Horse Collar" Clearance
I've searched and found a little information on this, but nothing too specific. I am putting the finishing touches on a dual case install with rear cv driveshaft. How much clearance (in inches) should I have between the CV and "the horse collar" that supports the gas tank, etc. Is 1/2" enough? I have a TG 4" rear classic lift, if that helps. I can also post a pic if necessary. I'm just not sure how much the CV normally moves under acceleration/flex. Thanks!
I see you're from Frisco. DIRTCO is from Frisco as well.
Also, I wanted to see if you saw this thread about the Colorado 4Runner Jamboree this summer and send you an invite https://www.yotatech.com/forums/f15/...2010-a-199370/
The CV on my '85 rubbed with dual case, you can see the shiny mark where it would hit below:
How I fixed it:
- http://www.4crawler.com/4x4/CheapTri...larCrossmember
How I fixed it:
kawazx636
Oct 6, 2021 03:03 PM
scott90
Oct 4, 2015 09:21 AM
4crawler, 4runner, c130, camping, clearance, collar, crossmember, cv, driveshaft, engine, horse, horsecollar, pic, tank, toyota
