Eliminating fuel evap cans question
Old Apr 8, 2010 | 12:58 PM
SloPoke's Avatar
I am building a carb'd 84 22R SR5 bob'd longbed trail rig and am wanting to do away with all the unnecessary crap under the hood.
I am having brain farts when it comes to re-routing the fuel lines.
In my head it works like I drew it up but if that's the case.....I still have an open vent port on my tank.
Will this work?.....and I just plug the extra vent port on my tank of am I way off?
Suggestions?
TIA
Last edited by SloPoke; Apr 8, 2010 at 01:00 PM. Reason: edited to add vehicle infomation
Old Apr 8, 2010 | 01:13 PM
vital22re's Avatar
totally a bro
if you remove the evap canister, you have nothing to control the vapor build up in your gastank. Not safe.
Old Apr 9, 2010 | 05:44 AM
SloPoke's Avatar
You mean other than the big vent line that runs up to the filler neck & vented cap?
I'm going to on it this weekend and was hoping to get a 'lil consensus from the yoat peeps before doing so.
It's shouldn't be very hard....I have just never messed with fuel systems much and wanted to get a heads up before I did. Besides, whatever I do can't be any worse than hooking it up backwards and getting fuel pouring out the evap cans. Peeps do that awl the time so.........I guess we'll see.
(off to get a couple fire extinguishers and a hose ready)
Old Apr 11, 2010 | 08:24 PM
peow130's Avatar
i dont think you realise how much fuel actually gets evaporated lol..
the gas only evaporates when there is enough air around it to get into the atmosphere. obviously in a gas tank there isn't that much air, hell, you couldnt even start a fire in a gas tank full of gas if you tried.
the fuel evap is there for a reason, and if you're worried about wasting gas, drain the tank after you're done wheeling and use it in your DD
Old Apr 13, 2010 | 06:43 AM
SloPoke's Avatar
ahhh...that's better
Sorry to disappoint but no hoses or fire extinguishers were needed.
OK, here's what I did.....
I ripped all vac lines off as well as evap cans, corresponding switches/sensors, and wiring harness pigtails.
I ran vac lines for the choke opened/closer, AAP, and vac. advance.
I ran the fuel lines like I drew it up except I put the filter between the tank and suction side of the pump due to space constraints.
I reinstalled the evap can by the firewall (the other was up front below the battery tray) and ran the tank vent to it.
I ran the vac line off the evap can straight into the manifold (no vsv).
That's it.
I wasn't so much set on eliminating the evap cans as much as I was simplifying things under the hood. I ended up keeping the one evap can as it was just the best option. I was able to eliminate the vsv on it's vac line and run just a single line to the manifold. The way it's plumb'd now, it's a catch can reservoir for leakage when I flop or roll. I was going to do the 3 sides and down thing but figured this a better option and it's mostly contained withing the intake system.
GreenLion
Jun 7, 2021 10:49 AM
Booger
Jul 23, 2015 08:25 PM
taraf
Jul 7, 2015 01:42 PM
racefan8
Jun 23, 2015 11:13 PM
