Hanging Chevys?
Old Apr 4, 2007 | 12:13 PM
Yota Tony's Avatar
I'm going to run the 10" shackles for now. Right now I just want to get to wheeling and what not. I can always build a new mount later and extending bump stops is easy.
Old Apr 4, 2007 | 05:24 PM
4Crawler's Avatar
Originally Posted by Yota Tony
So I'm going to go with a 10" rear shackle. This will let me use my stock hanger location. I've got some 3/16" plate laying around that will let me make 2 sets of shackles, no problems.
Looking around though, shackles are normally made for 1/4", the difference is .0625" not much but it could make a difference.
So do I use the 3/16 plate by it self or do I use 2 3/16 plate together (thus making the shackles 3/8" thick)?
I use 3/8" steel plate for my shackles:
- http://www.4crawler.com/4x4/ForSale/...shtml#Shackles
Old Apr 4, 2007 | 05:29 PM
getitdone's Avatar
Tony, you definatly need something thicker than 3/16. You wanna know how I know? Cause I used 3/16 plate for my front shackles...untill they folded over on me while I was on the trial. It will be even worse on your 9+ inchers, my fronts were only 6" eye to eye. I have 3/8 plate front and rear now.
As for the negative arch, my axle doesn't hit a bumpstop. The chevies barely go negative and if you do kink one, they are so cheap. I don't really think it's a problem.
Old Apr 5, 2007 | 09:43 AM
Yota Tony's Avatar
I'll weld two pieces of the 3/16" plate I have together then.
That will make them 3/8".
Bourbonblues
Dec 15, 2017 05:43 PM
rubrsidedwn
Jul 7, 2016 07:28 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
JookUpVandetti
Sep 17, 2015 09:25 PM
