Trail gear diff armor
Old Apr 2, 2007 | 07:47 PM
Sonofmayhem's Avatar
ok i have the front little armor on my truck and i wanna use the full one in the front and toss this one in the rear, does anyone have closeups of the diff armor in the front or rear? When i put it up against the diff it was off, like it wasnt wide enough. And i did have trouble with the small diff armor too.
Thanks
Old Apr 2, 2007 | 07:53 PM
Marc P's Avatar
Here you go..
Old Apr 2, 2007 | 08:02 PM
neilan's Avatar
if you havent already gotten one go fro the blue torch fab one it is awesome.
Old Apr 2, 2007 | 10:37 PM
Thanks
WOW mine is not that wide at all ill take a pic tommorrow to show what i mean. one of the sides on the armor touches the 3rd member welds with the other barely clearing.
Old Apr 3, 2007 | 04:50 AM
Stomis's Avatar
From what I've read your suppose to tack on end where it should be and use a mallet to make it fit snuggly. I dont think its suppose to fit perfect so when you hit it it gets like a glove fit and is snug.
Old Apr 3, 2007 | 05:09 AM
waskillywabbit's Avatar
Mine fit perfectly and the large welded on diff armor is a no brainer. BEEF!
Old Apr 3, 2007 | 05:11 AM
Marc P's Avatar
We had to grind the tube to the fill plug down a bit...other than that it fit fine.
Old Apr 3, 2007 | 03:49 PM
It seems to fit good on the front... Where it will be.
Thanks
Old Apr 3, 2007 | 03:58 PM
Stomis's Avatar
Is there room behind the beefy one to run the smaller one also?
Old Apr 3, 2007 | 04:37 PM
no well not the way my little one is. maybe with some grinding. but otherwise no.
Old Apr 4, 2007 | 08:51 PM
Volcom's Avatar
Why? The larger one completely covers the area where the small one would be. It would be a waste of time to weld it on just to cover it with the larger armor.
I have the large TG armor and it held up great in Moab. I used the front and rear several times.
I also shaved my diff plugs from the bottom of the axles, that made a ton of difference as well. No more hanging up and knocking the drain plug out of the axle.
Old Apr 5, 2007 | 08:55 AM
Napoleon047's Avatar
personally, i hate the large diff armor. they are just too big and ugly. the small armor has a much cleaner appearance that goes with the round toyota axle.
i have something identical to the small diff armor that i made myself and they have held up great on the front and the rear. if you manage to mess up the small style armor you need to learn how to drive.
Old Apr 5, 2007 | 07:10 PM
dirtoyboy's Avatar
I've seen the smaller (strip style) ones smashed in almost to the ring gear. i like my bigger one..the more distance between those nasty rocks and my ☺☺☺☺ the better. just my two cents
Old Apr 5, 2007 | 07:20 PM
Added some pics...I like the BEEF...as that little armor is just too flimsy...even if one can drive...add the BEEF!
XtraCab
Apr 12, 2020 05:25 AM
jerusry
Oct 19, 2015 05:28 PM
Scotto6591
Sep 1, 2015 03:24 PM
msane99
Jul 27, 2015 06:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
