Drivetrains and lifts
Old Apr 27, 2005 | 07:16 AM
ROOFGOOF's Avatar
I have been trying to absorb all of the pros and cons with suspension lifts. I am about to install a 2inch BL and wanted a few more inches.
I do alot of highway driving 70-85mph range and wanted to know if adding a few inches will take my driveline out of range that may cause problems.
The front set up I would like to do a cornfed 1 1/2inch spacer and 2 inch spacer in the rear OR 2 inch spacer front and 2 1/2inch spacer in the rear. (I like the slight rake look plus I am planning on adding a safari rack-which I figure would add some weight to the back). I am also going to add a diff drop kit.
I am hoping this minimum set up will keep my driveline happy... any advice?
Old Apr 27, 2005 | 10:40 AM
Good Times's Avatar
you can max out at 2.5" of lift all around and be fine. even with the body lift you should be fine. i don't personally own a 3rd gen but from seeing other 3rd gens out there i haven't heard of any problems here so enjoy liftin it
i'd go w/ a suspension lift first before a body lift. I'm not too fond of bl's so (even though i have one... go figure).
Old Apr 27, 2005 | 11:36 AM
ROOFGOOF's Avatar
Thanks for the info... I have read about a few vibrations, etc after lifting it up. I already have the BL from 4crawler. I felt this was the safest way to lift up my truck without effecting shocks, drivetrains, etc.
I figured with a 2inch BL and 1 1/2 to 2 inch spacer it should give me a good look with my 265'/75/16's.
I will absolutely get a diff drop kit for the front.
Any drivetrain experts out there willing to comment????
Old Apr 27, 2005 | 11:49 AM
terryjmatthew's Avatar
With a 1.5-2" suspension lift and 2" body lift your 265's are going to look tiny IMO.
I would install the body lift first (since you already have it) and if you think it needs more lift, then go with whatever suspension you choose.
As I stated ealier, I havent had any trouble w/ my 2" Cornfed spacers.(CV angle or otherwise)
Old Apr 27, 2005 | 12:11 PM
ROOFGOOF's Avatar
Cool, I am going to see how it looks... I was hoping to have my runner in the shop this evening to put the BL on and see how it looks. I will probally still do the 1 1/2 front spacer and 2 inch rear spacer (anticipating extra weight from the safari rack).
As soon as I get it done, I will get some pics up.
Old Apr 28, 2005 | 09:00 AM
ROOFGOOF's Avatar
Bump... anyone else have any comments on the first post ? Any issues or helpful info is appreciated.
Hope to have the BL on tonight !!!!
Old Apr 28, 2005 | 09:34 AM
jimbo74's Avatar
why not go with a 3" bodylift jsut to get that extra inch of clearance?
Old Apr 28, 2005 | 09:35 AM
jimbo74's Avatar
roofgoof, holy crap your signature is long.........
Old Apr 28, 2005 | 10:36 AM
ROOFGOOF's Avatar
I wanted to keep the BL no more than 2inches due to the increased issues with the 3 inch, plus I already bought the 2 inch kit. I am looking into the average life span with an increased angle in the driveline if I would do the spacer kit.
You are right, I will modify my sig.
suppra87
Jul 15, 2021 05:15 PM
punks_is_4x4
May 31, 2016 06:03 AM
choppe777
May 16, 2016 08:00 AM
Nick Berg
Sep 3, 2015 04:36 AM
Ryall
Sep 2, 2015 06:48 AM
