Custom brakelines?
Old Apr 26, 2005 | 08:23 PM
Praufet's Avatar
Custom brakelines?
Is it easy to make custom brakelines or get a local brake shop to make them? Or would it just be better to buy marlin or something?
Old Apr 26, 2005 | 08:43 PM
waskillywabbit's Avatar
Custom brake lines...are you talking regular hard lines or stainless steel braided ones??
If you are talking regular hard lines, just buy the tubing precut and flared w/ fittings to your specs. Nothing to it. I did that for my 85 when I redid the brakes and put discs on the rear. But I ordered my ss brake lines from All Pro to go from the hard lines on the frame to the hub for flexibility.
Old Apr 26, 2005 | 09:12 PM
deathrunner's Avatar
What do you want brakes for?
Old Apr 27, 2005 | 05:13 PM
Praufet's Avatar
I am doing cruiser coils in the rear and I need longer brakelines. I am talking about the stainless steel ones. Is there lines from some other vehicle that may work?
Old Apr 27, 2005 | 05:41 PM
Steveh29's Avatar
You can usually buy lengths of straight steel line at good auto parts stores and gently bend it to hug the rear axle or frame rail. They come in a number of lengths. If you're going to buy a long one and cut it to length, you'll need a double flare tool to reshape the end so it screws into the wheel cylinder or caliper or whatever you're threading it into.
Old Apr 27, 2005 | 09:38 PM
Praufet's Avatar
How would steel straight line work to replace the flexible hose?
Old Apr 28, 2005 | 05:03 AM
934rnr's Avatar
The easiest thing to do is goto the junkyard find another toyota pickup truck or 4 runner take the flexible rear rubber brake line off and double up your exisiting brakeline. As far as I know all the toyota TRUCK/4RUNNER rubber brake line fittings all have the same thread pitch so any toyota 2wd or 4wd truck should work.
BAM done for less than $5-10 including the brake fluid.
That's all I did to my rear brakes on my 93 4 runner with cruiser coils.
Or buy the nice $85 stainless steel brakeline kit from ALLPRO or Marlincrawler.
Old Apr 28, 2005 | 05:11 AM
mt_goat's Avatar
I got my SS flex line from Superlift.
Old Apr 28, 2005 | 11:40 AM
Praufet's Avatar
How much were they from superlift? Also if I use another brakeline to add the length do I need any fittings?
Old Apr 28, 2005 | 11:51 AM
mt_goat's Avatar
They were $33 each, but that was back in 1997. Here is a link: http://www.superlift.com/
Old Apr 28, 2005 | 12:08 PM
jimbo74's Avatar
if you know any companies that do stuff for racing, they make custom ss brake lines..... http://www.pegasusautoracing.com/
live4soccer7
May 11, 2016 06:52 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Brodetski
Sep 30, 2015 11:50 PM
toyotasaurus
Sep 24, 2015 03:30 PM
